Bow prop (Max power) error |
Mary400e
Lieutenant Joined: 05 December 2016 Location: Copenhagen Status: Offline Points: 27 |
Posted: 17 June 2017 at 20:59 |
Hi All
My existing Max Power bow thruster (retractable) is not working. I'm not able to start the bow thruster. When I try to activate the bow thruster via the control panel it says "Beep" and the "Up button" become green, but only for a second. Normaly the "green" stays on. I have replayed the control panel with a new one, but the error is still their. I have checked all the wiring, and the cable connectors. A couble of years ago have I cut the "white" wire to the temp sensor. Have you some idear to solve this error? BR Jesper (Tiramisu)
Mowgli
Lieutenant Joined: 27 May 2013 Status: Offline Points: 21 |
Hi !
Had the same problem, along with some nasty alarm buzers .... Cleaned all the conectors close to the box of the thruster and problem solved. Regards !! |
