jib screw lost |
Ida
Commander Joined: 18 October 2015 Location: Germany Status: Offline Points: 99 |
Posted: 06 November 2017 at 09:52 |
During the transfer to the winter camp, there was suddenly a loud jerk on the foredeck.
A bolt on the block of the jib had come loose and the sheet from the foresail broke away from the block. I had never checked the screws on the blocks. Does anyone have similar experiences? |
Hanse 385 #426, "eLisa", May2016, 3Cabins, Selden Mast, Elvström FCL, Furling Main, Draft: 1,63m, Volvo D2-40, Bowthruster
charentebob
Commadore Joined: 09 April 2014 Status: Offline Points: 403 |
Have not had this particular problem but I have had several blocks fail in different ways. Sheaves split around their circumference & side cheeks break up. I’ve replaced several with Harken blocks.
AndyS
Captain Joined: 14 June 2016 Location: River Dunes, NC Status: Offline Points: 195 |
As part of my endeavor to upgrade all of the hardware I replaced that block with one from Harken that seems to be very substantial. I would recommend the Harken ESP cruising hardware.
Andy
Moonraker River Dunes, NC |
kipwrite
Commadore Joined: 14 October 2015 Location: New York Status: Offline Points: 408 |
I’ve had three Selden blocks on my 505 suffer side cheek failure so far, two on the main sheet and one on the Gennaker sheet. This is a serious safety issue as the line is immediately jammed in the block when this happens, requiring major surgery to get things freed up and save the line. Upgrading to Lewmar HTX.
Edited by kipwrite - 06 November 2017 at 15:58 |
DotandDash
Sub Lieutenant Joined: 03 August 2016 Location: Annapolis Status: Offline Points: 17 |
We had the exact same failure on our Hanse 455. It happened offshore at 3:00 in the morning (of course). The loose bolt from the block got caught underneath a jack line (!), so it was retrieved, replaced and the sheet re-reeved.
Ist
Lieutenant Joined: 12 May 2017 Location: Oslo Status: Offline Points: 43 |
Nerthuz
Lieutenant Commander Joined: 25 December 2011 Location: Oslo, Norway Status: Offline Points: 67 |
We also had this failure on our 455.
