Unstepping the mast: a question |
Stria
Commander Joined: 04 December 2006 Status: Offline Points: 113 |
Posted: 29 January 2018 at 12:58 |
Hi everybody!
I will unstep the mast of my hanse 400e of 2007 in a couple of weeks... it will be the first time in 10 years and I frankly have no ideas of the electrical connections under the mast. In particular I wonder and ask you all, where does the Is12 wind transducer Simnet cable end? Does it go all the way to the Is12 wind instrument in the cockpit? Or does it end in the cabin with a plug to Simnet??? Thanks for helping !!!!!
Wayne's World
Stria,
We don't have a 400 but on our boat the wind transducer ends just forward of the mast under the floor in the fwd cabin where it plugs into the network. I would think yours would be similar.
415 Singapore
Vice Admiral Joined: 23 September 2013 Location: Singapore Status: Offline Points: 826 |
Hi on our 415 there are small removable ceiling panels front and back of the internal mast support, unscrew these and the connectors are in there.
Good luck Paul
Paul - Night Train - 415 #136
arie
Lieutenant Joined: 04 February 2009 Location: Netherlands Status: Offline Points: 36 |
On my 370 2007 the mast connectors all are in top section of the port cupboard of the front cabin , behind a small wooden panel that needs unscrewing . I think your 400 must be very similar .
Free Stile . Hanse 370 #452. Sailing Aegean Sea from Leros, Greece
Captain Cook
You have to remove the interior plate in the cieling around the mast foot. There you will find the connections to all the cables in your mast. 4-6 screws as I remember. Someplace in this forum there is a picture where you can see the assembly under the cieling.
Captain Cook
I just did the searching for you:
Hanse 371 Topic: "Mast removal" from 11/5-2016 ......search the topic and mark "any date". More pictures and advice in the topic. Edited by Captain Cook - 29 January 2018 at 16:55 |
Fendant
Just an advice to make the reconnection easier. Before disconnecting use adhesive labels and number all cables both ends from 1 to ..... Then you have it easy to reconnect the right ones. Be aware that the colors of the cables from the mast do NOT match the colors of the cables from the switchboard, some might , some might not.
Stria
Hi guys!
Thanks everybody for the help... and thks to captain Cook for the archive search. Great forum. Fair winds from Italy J
Heikki
Commander Joined: 15 November 2014 Location: France Status: Offline Points: 82 |
I have to unstep my mast also for road transport, thanks for all hints! Does anyone know the max. height of Hanse 400e (2006) mast unstepped from keel to the highest point (top of halyard winch or bow pulpit)? The transport company wants to know this to avoid tunnels and bridges with low clearance. Regards, Heikki |
Melanie
Hanse 400e #121 |
Bruno
Commander Joined: 13 August 2014 Location: Bromont, Quebec Status: Offline Points: 104 |
Heikki,
If you boat is out of the water, I would recommend you to have it measured by the transport company since it will be their responsibility. They will determine what is the highest point of the hull and see if the balcony, wheel(s) or winches must be removed. They could decide to carry it with the bow slightly lower and leave the balcony in place. Bonne chance! Bruno |
Bruno
Hanse 400, 2010 Hull 660, Canadian flag sailing Lake Champlain, VT USA |
