Self Tacking Jib |
Post Reply | Page 123> |
German
Commander Joined: 01 April 2017 Location: Brazil Status: Offline Points: 80 |
Posted: 14 August 2018 at 23:12 |
My Self Tacking Jib has some clews critically deformed after 4 years of usage. As you can see in the picture, it became very dangerous to continue to use the sail. Any recommendation? Did anyone had the same problem? Thank you
German
German
I am sorry. I tried to attach a picture, but didn't work...
German
Please see picture
https://photos.google.com/photo/AF1QipOyQ4PER9bm5voGS_c25b0P0pDt61WL7bmEsaAb
Black Diamond
Get a 404 error (not found). Cannot see the picture. Keep in mind that the picture (I think) cannot be more than 500KB. You might need to lower the size or resolution.. |
German
Please use this link
https://photos.google.com/photo/AF1QipOyQ4PER9bm5voGS_c25b0P0pDt61WL7bmEsaAb Thank you
Wayne's World
German,
Your link shows as an error. If you have an early headsail you may find the clew board is not up to the loads involved. We had our clew board replaced under warranty when the shackle pulled through one of the fixing points. Before the clew board was replaced we used two bow shackles to attached the self tacker sheet to two of the undamaged fixing points on the clew board. This spreads the load over two fittings and lasted for a few months and probably would have still be working now but the clew board was replaced with a much stronger unit. Hopefully you can still post the image just to check we are talking about the same problem.
Black Diamond
You should also take a look at my post on selden furling gear in the 575 discussion area. The halyard tension required for most membrane sails is often much more than the selden gear was designed for. Be careful you are not using your electric winches with too much gusto. The winches can overpower the clew hardware as well as the halyard swivel at the top of the mast. |
German
Thank you for your comment. Yes, I have been using my jib really tight. Sometimes I even put the boat against the wind to tight even more the sail and get a lower AWA. Maybe this is the reason for the damaged clews.
marcopone
Commander Joined: 24 April 2013 Location: Italy Status: Offline Points: 137 |
The clews are too weak.
I had a clew broken and the Jib has been seriously damaged because of the recoil. The self tacking Jib was the more expensive Elvström type. Take care. After this issue I ordered a not self tacking 105% genoa. The boat runs much better and tacking is quick and easy. Yes, also before this issue I was hating the self tacking jib! |
