blue hull fading |
Post Reply | Page 123 5> |
Author | ||
Wieland1
Lieutenant Joined: 16 October 2013 Location: Willemstad Status: Offline Points: 34 |
Posted: 02 October 2018 at 16:54 |
my dark blue 312 is fading "chalking" mostly aroud the bow end. has anybody had experience how to deal with this?
i tried car polish . looked very good- but only for 3 weeks. would special stuff like from 3M do a better job? or is polishing hopeless and repainting or even "wrapping " the only solution? I would appreciate hearing from anybody who found a solution? thank you! |
Wieland1
Rubato
All coloured gel coats have this issue eventually - called oxidization.
If the hull is fairly new (a few years old), then using an oxidization remover (rubbing compound) first followed by a good wax will restore it for a number of months. Eventually though, after a number of years, even that only lasts a month or two. Doing that on my 2007 looks good for about 1 month then I can start to see some chalking again and after 3 months it's looking sad once again. I recently talked with a fiberglass expert at a boat building/repair company. He said that at this point I should have the whole hull wet sanded starting with around 400 grit and then progressively down to 5000 and then the polish. This will restore it to new. When I have a few thousand dollars laying round I may have it done (I won't have the time to do it myself) Here's the products I currently use Polisher https://www.makita.ca/index2.php?event=tool&id=1905 Oxidization remover https://meguiars.ca/product/marinerv-heavy-duty-oxidation-remover/ wax https://www.westmarine.com/buy/meguiars---56-boat-rv-pure-wax--443226 Note, don't use the one step cleaner/wax. They don't protect that well. For the removing the oxidization, use a good foam pad specifically for rubbing compounds (they are very firm). Alternatively, you can use a wool pad that is specifically for that purpose. The wool is a bit more aggressive.
Hanse 400e, #168 |
Wieland1
thank you very much , Rubato for your very useful answer to my question
all the best from Wieland
Wieland1
daveg
Sub Lieutenant Joined: 10 January 2005 Location: United Kingdom Status: Offline Points: 9 |
I gave up a few years ago trying to keep my dark blue hull glossy - the effort every year was not worth the couple of months it stayed good. The answer is to have it vinyl wrapped - choose your original colour or a new one. I've had minor damage caused by a burst fender scrape the vinyl but that was quickly and cheaply repaired. Dave |
Pieterman
Captain Joined: 05 December 2015 Location: Oostende Status: Offline Points: 184 |
This winter I will re-paint the faded blue hull of our 315 Pieterman. With good sanding and the use of the correct paint, I hope the result will be OK. We chose to stay with the lovely blue color. And we keep our fingers crossed...
Pieterman
Hanse 315 (2007) BEL7000 |
samuel
Hi Pieter Sounds good----I shall come over & inspect it 10 August 2019 when I come for the Paulusfeesten Might even buy that coffee I owe you Samuel
grumpydatagit
Captain Joined: 22 August 2015 Location: Lymington Status: Offline Points: 225 |
I have a light blue hull 315 which someone punched a hole in last year - I the guy was good and paid for it. However, the original colour gel coat colour and the hull had a massive difference in colour. The only way they could get it to match was to sand it down the hull with 600 paper to get to the same colour as the repair and then use Aquabuff 2000 to finish off. The other thing I noticed last year before the accident on the other side of the hull , was where I have a 2 metre cloth over the side to protect from fender rub, there was no UV damage to the hull under this cloth from the year previous polishing. So this year I'm going to make up some fender cloths that go most of the way along the hull.
Ta'I Miti 2
Captain Joined: 05 April 2016 Location: Brussels Status: Offline Points: 237 |
Last winter (march 2018) I had my white hull cleaned and polished by a shipyard
I thought she was a new boat It's now december and the hull is as she was before although the hull as rinced after each cruise This is not only a "coloured hull" problem |
Not only those who wander are lost
I've learn that the best way to learn about people is to sail with them |
Pieterman
Update!
This week we sanded the hull of our 315 Pieterman. My son did most of the hard work. Some little holes were filled. Next week the hull needs a last sanding and cleaning. An then it is time to re-paint. I'm looking forward to this job. Instead of the two white lines at the waterline, we will paint the antifouling a bit higher (to the bottom of the current thick line), then have one smalle blue line and above one broad line (to the top of the current small line). This broad line will continue to the very front of the bow so the port and starboard side become one. It will not be Hanse-Hanse, but it will be to my liking. I'm looking forward to it. |
Pieterman
Pieterman
Hi Samuel, You're always very welcome in Ostend. I'm looking forward to the coffee, and perhaps a Brugse Zot as well. Pieter
Pieterman
