Loose heater tube under closet in rear cabin |
2203
Sub Lieutenant Joined: 18 October 2018 Status: Offline Points: 3 |
Posted: 18 October 2018 at 20:58 |
I was trying to modify the heater tubing to get better heatflow into front cabin. This went wrong, and I think that the tube is disconnected under the closet in rear cabin. Can I Access the hose under the closet? How can I remove the closet? |
Merinalle
Captain Joined: 16 January 2007 Location: Finland Status: Offline Points: 288 |
No answers yet? Obviously you are the first and only with this kind of problem. Our heater is not a factory installed one, but maybe I can give some hints. Removing the closet seems to be quite difficult. Our installer approached the area under the closet horizontally, not vertically. Here is a picture of the opening (without the cover).
The other picture is made upwards from the hole. As you can see, there really seems to be some kind of horizontal opening in the GRP. Again, I can’t imagine how to reach it without removing the closet.
Hope this helps you Edited by Merinalle - 24 November 2018 at 13:46 |
320#166
2203
Thanks a lot for the pictures. They were really helpfull.
I ended up cutting out the floor on the right side of the closet, - so that I could access the large hole in fiberglass underneath.
Merinalle
Nice to know the
pictures helped you, although I had mixed vertical and horizontal on my
original text. Now it is edited to be more logical.
320#166
