problemi elica |
sergio
Sub Lieutenant Joined: 08 September 2008 Location: Italy Status: Offline Points: 2 |
Posted: 08 September 2008 at 11:23 |
Ho un hanse 371 del dicembre 2003 con elica opzionale del cantiere a pale abbattibili.
Ho sempre avuto problemi di velocità a motore: max 6,3 Kn con carena pulita a 3200 giri (yanmar 29 CV)
Qualcuno sa chi è il costruttore dell'elica e se si può fare qualcosa prima di cambiarla?
Grazie anticipatamente
alettaenmarcel
please in English or els maybe better post this on the italian forum part!
greetings Marcel
sergio
I have a Hanse 371 of december 2003 equipped with shipyard optional overthrowable screw propeller.
I have always been experiencing speed throubles when sailing with engine: max 6.3 kn with clean bottom (hull) at 3200 rpm (yanmar 29 CV engine)
Does anybody know who is the propeller builder ? Any suggestion before proceeding to substitute it ?
thanks in advance for your advises
Terry
Captain Joined: 04 August 2006 Location: United Kingdom Status: Offline Points: 214 |
I have a Yanmar 55 on my 430,and I dont think you should be going at 3200!!
61/2k on a 37 does not seem too bad.
Terry
"ELYSIUM" 430e |
Peter-Blake
I have a 370 with a 3 blade flex-o-fold prop. and the 29hp motor.
if i give full power with about 3600 rpm it is possible to reach 7.7 kn-7.8kn without any wind and waves.
I think with 3200 rpm it is no problem to go over 7kn easy. i will check it this weekend.
If i motor with about 2.600 -2.800 rpm i think it will go at about 6.5 kn
Blake 370
Stella*Nova
Vice Admiral Joined: 25 January 2004 Location: Lelystad / NL Status: Offline Points: 776 |
Same equipment, same experience.
BR Ralf, Ex. 'a mare' H370
lukemi
Commadore Joined: 06 February 2007 Location: United States Status: Offline Points: 439 |
Hmmm.... I have a 370 with a 3 blade flex-o-fold prop with a 39 hp motor (3JH4). My MAX speed with throttle fuel open is 6.5 SOG at 3200 rpm. Reading this post, I may want to get a Yanmar mechanic and see where my extra 10 hp is going.. No problem using the extra fuel though...
Stella Maris#166
Peter-Blake
This sounds not good lukemi. 6.5 kn with a 40hp at full power. This cannot be true. There must be something wrong, or did you forget to antifoul your boat ?
In teresting is that my 3ym30 has a max rpm of 3600. and that is what i get i i give full power, nothing more.
The 3JH4 has a max rpm of 3000, why do you reach 3200 rpm???? this is 200 rpm more than it should Edited by Peter-Blake - 11 September 2008 at 16:03 |
Blake 370
lukemi
Blake, thanks for the reply. Yea, I really have to push the throttle to get that last 200 rpm. I usually do not go above 3000 (usually cruse at ~2600). In spring with a clean bottom I maybe got 7 to 7.2 knots best case. One thing for sure, I have never got to 7.8 in best of conditions (except by sail). Maybe this is an advantage for the 3YM30 and higher RPM capabilities. Mike |
alettaenmarcel
my engine also reaches 3200 rpm
This can be a difference in the meter witch shows the rpm or some other thing .
My speed max is 8.3-8-4 knots at full power with my 40 hp.
Wenn speed is not reached you can check the coupling plates or the oil evel off the coupling .. it might slip.
greetings Marcel
