Bow Thruster not working (Max Prop Compact Retract |
Mary 400e
Lieutenant Joined: 23 January 2007 Status: Offline Points: 25 |
Posted: 17 July 2011 at 10:22 |
Hi All Yesterday when we sailed out on our summer vacation trip, the bow thruster worked well for 10 sec and then it just stopped and retracked automatic. When I try to start the bow thruster it make one buzz and the LED (ON/Off button) flash one, then nothing. I have checked all the wiring and fuses. I can operate the bow thruster in "Manuel mode" as descriped in the manuel, and I can change to "Automatic Setup mode" and the thruster run the procedure with no problems. But the thruster will not start. I have inspected the bow prop in the water and it can run free, and it all looks normal. Help wanted :-) Best regards Jesper |
Tiramisu 400e (DEN-161)
lukemi
Commadore Joined: 06 February 2007 Location: United States Status: Offline Points: 439 |
Jesper,
Basically the same thing happend to me last month. I went to use the thruster and I got one long tone, a blinking green LED, then it shut off. I called Max Power and they immediately knew the problem. Apparently the compact retract has a bad design with the internal temperature sensor. After a period of time, the sensor goes bad and the thruster will not engage. There is no way to repair this sensor!!!! The solution was to cut the two white wires to the sensor. This worked fine for me. The thruster has been working fine for the last 4 weeks. The dealer indicated that this has been a major problem with the earlier units. The newer units apparently have 2 temperature sensors. Since I rarely use my thruster for more than 10 seconds "thrusts", the dealer did not think it would be a problem for me to run without a sensor. Check with your dealer and discuss this possibility. Manuals are online so you can review wiring diagrams for any wires to cut if necessary.
Stella Maris 370e#166
Mary 400e
Hi Mike
Thanks for your feedback, I will make a test tomorrow morning. Best regards Jesper
Mary 400e
Hi Mike
I have cut the 2 white wires to the temperature sensor and now the bow thruster is working perfect. Thanks for your help. Best regards Jesper
Edited by Mary 400e - 21 July 2011 at 21:19 |
Rubato
another happy ending on the myHanse forum. Woohoo
Hanse 400e, #168 |
lukemi
Jesper
I'm glad to hear this worked for you. That is one of the great benefits of the Hanse forum. I have learned a great deal about my boat over the years from this forum. I'm glad to also help when I can. As Rubato says "another happy ending" because of the select group on this web site.
Regards, Mike
Stella Maris
alanvkrasno
Lieutenant Joined: 21 February 2011 Location: United Kingdom Status: Offline Points: 23 |
I too an having trouble with my Retractable 12v Max Power Thruster. It worked v well but suddenly all I get when trying to turn it on in the usual way is a longer pause then a 3 sec beep. And no lights come on I cant get any help as Max Power/Plastimo are in Administration. My last resort is to cut the sensor wires tomorrow as suggested .
Has anyone sourced or replaced the sensor that is malfunctioning?? |
paul_heinz
Lieutenant Joined: 09 June 2012 Location: Den Osse Status: Offline Points: 44 |
I´ve had the same problem with the maxpower compact retract.
I got the advice not to replace the sensor as this was close to impossible. I should only take care not to overheat the thruster (no more than 3 minutes as per usage) As I usually use it only for less than 15 seconds its all fine with me and I didn´t replace. I know another H400 owner who is using the thruster for now 6 years without an problem. |
VagaMundo
Sub Lieutenant Joined: 08 October 2013 Location: Panama City Status: Offline Points: 1 |
Hi all.
I've installed this device from 2008. Two years after, in a windy journey, I was used the Compact Retract a lot of times during the docking maneuver but shortly time every time. The temperature sensor is breakdown. Provisionally fix the problem by cutting the sensor cable to leave open circuit. Talking with my dealer, I ordered a new one sensor. when I had the sensor I lift the boat to maintenance and to repair de bowthruster. To replace the sensor had to remove the electric motor to the wire winding. Inside I found that there were two sensors, although only one was connected, the other showed their cables in order to change a sensor by the other. But I changed the damaged sensor and plugged it, leaving the original replacement sensor ready for next time. Everything worked fine after the repair, but the work is delicate and you must have good tools and lots of patience. Yesterday came back to fail the device on a windy maneuver. I still have not checked the fault but I can imagine that this is the same breakdown. I think these sensors are too sensitive and should not fail in a maneuver that really was not abusive (no more tan 20 seconds!). Certainly I will let the white wire disconnected and I´ll use the bowthruster with common sense, since I'm the only one who handles my boat. This is my experience and opinión. Thanks! |
dr.amon
Sub Lieutenant Joined: 13 August 2014 Status: Offline Points: 11 |
I have had the same problem with my bow and stern thrusters like this and electric technician have said me that directly connect the cable, I understand te problem now,
Thanks.
