Boom on 355 |
Post Reply | Page <12345 6> |
Pluggen
Sub Lieutenant Joined: 18 August 2012 Location: Sweden Status: Offline Points: 6 |
I have also broken my bom when I was doing an ordinary gybe in 17-18 knop wind.
It was an Z-spar. Does anyone know if Hanse has a plan for solving this problem? Is there anyone which have had the same problem with a bom from Sparcraft?
Pluggen
Perttu
Captain Joined: 13 October 2006 Location: Finland Status: Offline Points: 243 |
Pluggen, that is not nice to hear...
Where does the boom brake? Photo would be fantastic.... |
Pluggen
Pluggen
Pluggen
Pluggen
Pluggen
Pluggen
handsome
Sub Lieutenant Joined: 21 March 2010 Location: Netherlands Status: Offline Points: 7 |
Looking at the picture of Pluggen I noticed that also on his boot the boom is not rigged properly. As you can see the boom has a third eye which is not in use. All the forces are now focussed to the point where the boom snapped. The best solution is to have the last block of the boom in the picture of Pluggen on the cockpit roof and an extra block at the boom (middle eye not used in picture).
The forces for the boom by the last block will be reduced with this setup. Same reasom why you should use a block for the jib to reduce forces on the mast by half.
Mine is holding up since I changed.
HANDSOME
Brufan
Rear Admiral Joined: 16 December 2010 Location: Belgium Status: Offline Points: 629 |
Usally the third point is for the sheet fixed point.
I don't understand why the aft block has a becket. By the way Selden booms seems much thickier the Z Spar. It seems also much much heavier Since delivery I never saw mine bent (even when hard gybe with 20+ knots)
Bruno
hanse 355 - 57 S/Y Spicy Ginger White hull, 2 cabins, Volvo D1-30, Selden rig, removable mainsheet track system, Simrad (now B&G)-Jefa autopilot. |
Perttu
Pluggen, thank you for the photo.
Z-Spar boom is flexible - when tacking hard it was certainly flexing a bit. Now this may not be a problem since flexible structures can be extremely strong as well. I did *intentionally* a very challenging gybe around 24-26 knts true winds with full main just to see nothing would brake when boat was brand new. And nothing happened, boom is not bent etc... Now with a cockpit traveller boom seems very firm in my case. It is true that sheeting point is not too far from the mast without. On my boat aft block also had a becket, but sheet was fixed to middle eye. |
Jøvani
Captain Joined: 20 April 2009 Location: Norway Status: Offline Points: 175 |
Just
include a picture of how I have arranged it on my 411. Except for a higher load
it is probably identical to the 355 arrangement. As you see from the picture I have 3
connection points to the boom to distribute the load. Have used it like this now
for 3 years and so far no problems. My 411 was originally equipped with a
cockpit traveler, for different reasons I like this solution better, but
realize the boom load disadvantage. I
calculated the increased load on the boom and selected Harken equipment
accordingly in cooperation with Harken Sweden.
Jøvani
Jøvani Hanse 411 #189
Tønsberg Norway |
Pluggen
I was just on my way to sail home from Greifswald when the bom cracked, and the rigging was made by Hanse. So dont want to pay for the new bom. I think it should be on the guarantee and on the responsibility of Hanse. The best should be if the exchange it with a Selden or Sparcraft. With a Z-spar it will still be to weak.
Pluggen
