Holding tank capacity Hanse 505 |
Post Reply | Page 12> |
kemalgunduz
Sub Lieutenant Joined: 09 October 2013 Location: Turkey Status: Offline Points: 15 |
Posted: 18 October 2013 at 14:18 |
Hello to everyboday,
As a new member of this forum I have read very useful information during the last two weeks. I do not have a boat at the moment but I seriously thinking to purchase a 505. I am living in Turkey and during the recent boat show I had the possibility to see her. In my country the authorities have put a new regulation regarding waste discharge. In any case you are not allowed to discharge the holding tanks overboard. You have to either return to marina or ask for a waste collecting boat and have to deck pump our the wastes. Discharging overboard is subject to quite high penalties and the authorities can easily find out if you do so ( by an electronic card which having onboard is mandatory) As a matter of fact, the capacities of the holding tanks become very critical and as far as I know the capacity is around 35 liters for each tank. During the boat show I have checked the heads and it seems to see and to check the waste tanks is quite difficult. My question is if anyone knows how to increase the capacities, and also if it was possible from the design point of view. May be the right person to answer shall be vzr1800 as I suppose that he/she is a Hanse employee. Best regards
Fendant
Same for me in Switzerland. You are right the capacity of the holding tanks installed by Hanse is ridiculous. They are only 32 ltr, but the real capacity is just below 30 ltrs. Furthermore against all holding tank regulations no sensor indicating a full tank is installed.
If it is full it will overflow through the vent, if you get caught in Turkey this will cost you a fortune.
I went for a separate grey water tank (134 ltrs ) and I must confess that this was a mistake. I should have gone for a stainless steel tank for grey and black water installed in the cockpit locker. I had a look and there would be enough space to fit a bigger tank ( maybe 50 - 60 lts in the cavity behind the toilet (s). The problem is that you will not be able to fit it in, due to the small opening.
kweetje
Commadore Joined: 15 September 2009 Location: Belgium Status: Offline Points: 360 |
in Belgium & Holland we have similar regulations...
Here these regulations seem impossible to inforce, most marinas have pump installations... defective or not working since ? Maybe more than 5 years. The choice is obvious (and normal) i guess... |
First 4000 miles, no substantial problems
Wayne's World
The regulations in Australia change from state to state but in Queensland sense has prevailed with "no discharge" zones like rivers, harbours, marinas and within one NM of reef areas or the coast. Commercial vessels (charter operations) need to have holding tanks and when discharging outside the no discharge areas they need to "treat" the discharge. The minimum treatment is only maceration so the discharge quickly visually disappears. If a vessel has a full sullage treatment plant onboard then they can discharge at the reef areas but still not in rivers, harbours or marinas. All recently built marinas need to offer a pump out sullage facility but they are very rarely used.Most boat owners say that if the government makes the fish, whales, dolphins and seals stop pooping in the sea then we will stop as well but until then we see only minimal impact from a small vessel discharging a relatively small amount of sullage into an open sea environment. After all if you are a sea for a week what choice do you have?
alain
Commander Joined: 24 September 2009 Location: Aegean Sea Status: Offline Points: 94 |
I have made the same experience -- the black water tanks are too small sailing along the turkish coast. I have the boat in Marmaris during the winter and the tanks have now been replaced by custom made ones with double capacity. I also tried to find a valuable solution to measure the level in them - but I have not found any system to work acceptable so far. If you are interested I can indicate you the company which made the tanks for me. |
alain
H445 #26 |
Fendant
Grüezi Alain,
I had the same problem and finally found a system which can be retrofitted even to the factory installed tanks without Drilling holes ore removing the tank in order to install it. It does not have any mechanical parts, so it should be really reliable. I will install it in a couple of weeks ( today its snowing ) and report here in the Forum. Frank
alain
Grüezi Frank
Many thanks for your input -- I am keen to read about your experience with the Gobius sensors. (Can they still mesure once the tank is inside dirty and lime has attached to the walls?) 'Fendant' -- are you a wine maker from Wallis :-) ? Where do you have your boat? |
alain
H445 #26 |
Fendant
Salut Alain,
contrary to mechanical floating sensors ultrasonic sensors should do the job with a significantly improved reliability. Theoretically a thin layer forming at the tank walls should not influence the measuring process. I would have gone for the Philippi ultrasonic sensor, which requires a 52 mm hole for the SAE flange in the top of the tank.This was not possible for 3 reasons: 1) You don't have access into the tank, the Hanse tank stupdidly does ot have a Service opening. 2) You have to disconnect the tank, so the sh..t will spill on the washroom floor 3) You have to remove the tank, which is close to impossible with the fixed metal bracket Another reason is that I still hope to have a larger plastic tank fabricated at a later stage, so I could reuse the sensors. best regards from the lake of Constance
Wayne's World
We have had a Gobius sensor
system fitted to a large aluminium black& grey water tank and it has worked
well for about 3 years since fitting. The system uses three sensors which are
glued to the outside of the tank and "see through" the tanks wall. The
system works on tanks made of aluminium, steel , stainless steel, fibreglass
and plastic. Because there is only three sensors the readings are given as
below qtr, between qtr and half, between half and three qtrs and lastly full.
The highest sensor can be fitted slightly lower than the top of the tank so you
have some head space so "full" is not over flowing. Our system did
not have a audible alarm so you had to look at units light display to check the
level. I guess a high level audible alarm could be fitted. The only problem we
experienced was the controller unit which displays the level lights to show the
liquid height would get confused when it was the power was disrupted. The
system then had to be repowered and the correct code used to tell the system
what the tank was made of before it would show the correct indication lights. We had ultrasonic sensors
for our fuel and water tanks which were fitted when the boat was built. This
system was programmable to allow for irregular shaped tanks and had variable alarms
for high or low level and was accurate and reliable. The readouts showed the level
in litres. The price of the
ultrasonic system was in the several $1000's each whilst the Gobius cost about
$400. The Gobius unit was easy to fit. |
Fendant
Thanks very much for the info Wayne.
I am planning to fit an additional analogue Display to the conrtoller, the other option would be to leave the controller permanently powered up.
Edited by Fendant - 23 March 2014 at 23:51 |
