What is the best autopilot for a Hanse 320? |
Post Reply | Page <12 |
Louba
Commander Joined: 08 January 2012 Location: Mediterranean Status: Offline Points: 80 |
Dear Claude.
Thank you very Much. Louba of Marseille
mystudio
Captain Joined: 17 April 2018 Location: Netherlands Status: Offline Points: 157 |
I'm fitting my 320 also with a DD1 drive. However, it seems to be impossible to apply the 106mm offset Jefa is talking about. Does anyone have experience with this? Mounted it in other ways which also work? Please, let me know if you do (or don't). Thx in advance. |
iemand
Alu van consider a sd10 Drive instead.....
Louba
Voilà le nouveau pilote est installé.
My New autopilot is installed. Louba |
Louba
Louba
In the previous post, a picture of the installation of Autopilot JEFA in my H320. It's coupled with Raymarine electronics. Louba
Edited by Louba - 06 June 2018 at 07:48 |
Brufan
Rear Admiral Joined: 16 December 2010 Location: Belgium Status: Offline Points: 629 |
Louba,
Le cable de mise à la terre de la mèche de safran doit être enlevé suivant la note de JEFA. Mon bateau avait fait l'objet d'un "rappel" à ce sujet.
Bruno
hanse 355 - 57 S/Y Spicy Ginger White hull, 2 cabins, Volvo D1-30, Selden rig, removable mainsheet track system, Simrad (now B&G)-Jefa autopilot. |
Louba
Bonjour Bruno.
Merci pour l'information. Est-il possible de me faire passer cette note? Nous n'avons rien vu dans les documents d'installation. Je voudrais en informer mon installateur. Et où doit-on relier le câble de mise à la terre? Olivier (Louba) |
aquilo
Lieutenant Commander Joined: 09 September 2008 Status: Offline Points: 70 |
Hi. I am installing the Ev100, instruments and controllers installed OK on to the simnet bus. But I struggle to find where the autopilot circuit +12V cable from the breaker panel goes. It is rather thick and color is magenta, but it sees to "disappear" into a black hole. Not able to locate where it ends, even after several hours searching.
Any suggestions? Edited by aquilo - 12 June 2018 at 19:38 |
Hanse 320
Norway |
Brufan
Il s'agit d'une note de JEFA émise lorsqu'ils ont appris que Hanse raccordait la mèche alu à la 'terre' du bateau.
Il y a un risque renforcé d'électrolyse de la mèche. Il faut simplement la déconnecter de la mèche (un coup de pince coupante...) et ne la raccorder à rien. (certains craintifs font pendre une anode au port directement raccordée à la mèche ; un peu comme sur les bateau en alu)
Bruno
