Crack in the inner liner |
GoranT
Sub Lieutenant Joined: 05 December 2017 Location: Sweden Status: Offline Points: 3 |
Posted: 06 December 2017 at 09:52 |
New in this forum and a new, most happy owner of a 2008 Hanse 320.
I have discovered a crack at the rear beam, see picture.
Took up yacht on land for winter storage just after purchase. Has started cleaning in hidden spaces and found a crack in the inner liner. The crack was not open when the boat lay in the water but opened up when landed. The crack is old, as seen in the picture. Something to worry about?
The boat was bought by a company so I will definitely contact them. Anything else to do?
regards Göran
Edited by GoranT - 06 December 2017 at 10:04 |
iemand
Admiral Joined: 13 February 2004 Location: Germany Status: Offline Points: 1082 |
Hello,
I'm pretty shure that the bot hit a rock seriously. The keel pushed in the hull on the backside. That's why the crack is now open again. If you take away the antifouling / primer on the hull around the back side of the keel you will find cracks as well. You should document everything - especially the keel front side how it looks like now and claim the repair from the seller as "hidden failure". Maybe you should take a surveyor. Good luck.
cptgood
Commadore Joined: 26 August 2016 Location: Tuscany - Italy Status: Offline Points: 409 |
I have a 320/ 2008 too...where the crack is precisely (cannot understand from the pictures) ?
redlion
Captain Joined: 28 August 2013 Location: Creran Scotlan Status: Offline Points: 188 |
I agree with iemand. It would appear the Keel has taken a serious hit. The keel will have to be removed and some serious work done on the hull, grinding out the damaged fiberglass and repairing with epoxy..expensive. I would get the ball rolling now in terms of estimates for repair as you will not want to miss next season.
plattgatt
Captain Joined: 22 December 2010 Location: Germany Status: Offline Points: 175 |
Hallo Göran, Der angezeigte Riss ist zwischen Rumpf und Innenschale aufgetreten. Ich erinnere mich, dass die Innenschale nur mit verdicktem Polyester ohne überlappendes Laminat an die Rumpfschale geklebt ist. Offensichtlich haben sich diese Strukturen getrennt, was nicht gut aussieht. Da die Rumpfschale auf dem Foto keine Risse aufweist Schauen Sie sich den Rumpf an der Kielwurzel genau an, innen und außen, bei einem heftigen Bodenkontakt befinden sich im Bereich der Hacke innen und außen Risse im Laminat auf. Wenn Sie Zweifel haben, nehmen Sie einen Gutachter, der das Problem betrachtet. Grüße aus Hamburg Bernd
370#641 "aqua d`or"
GoranT
Thanks everyone. I have contact the dealer and waiting för reply. I will not let this go without getting it fixed.
I will try to post a better picture of were the crack is. /Göran |
