Question: Mast Base Blocks |
Post Reply | Page <12 |
Borjebus
Commander Joined: 29 January 2013 Location: Sweden W Status: Offline Points: 111 |
Hi For Pete's sake,
You are facing the same dilemma as myself - clevis pin holes 6 mm limit your choice of blocks. My boat is a 370e and I have 57 mm blocks, except for halyards where I have 75 mm. That is when I have removed the 6 mm limitation. Why not do the Bernstein solution? It gives you plenty of blocks to choose from.
D0bbies
Captain Joined: 05 August 2014 Location: Falmouth, UK Status: Offline Points: 247 |
Hi "For Pete's Sake
" As I am the originator of this post I cannot answer your question directly. I would therefore suggest you send a PM to "Borjebus" as he was the contributor of the information you require in post 8. Cheers |
2005 312, Tiller, Engine 2GM20, SD20 Saildrive. Facnor SD 130 Furler.
