emergency tiller
Forum Name: 575
Forum Description: 575 Hints, Tips and News
URL: http://www.myhanse.com/forum_posts.asp?TID=10222
Printed Date: 20 September 2018 at 22:09
Topic: emergency tiller
Posted By: RolandHaas
Subject: emergency tiller
Date Posted: 19 April 2017 at 22:20
all screws of the plastic fitting on the emergency tiller except one are broken. Did anybody have a similar experience and any advise on how that can happen/which risk it imposes?
Posted By: bovine
Date Posted: 19 April 2017 at 23:14
Hi , the only way this could happen is crevice corrosion. Water has got down the bolt holes and stagnated
Date Posted: 21 April 2017 at 09:48
Thank you.
Do you think that the rudder must have hit something in order for the screws to break. There is also no rost on the screws.
Date Posted: 21 April 2017 at 13:00
They may have been over tightened at manufacture in the factory. This may have happened if the operative had used an air operated impact wrench with the torque setting too high. If the screws had been bedded in sikaflex no one would have known afterwards & the operative may have not bothered to change the broken bolts.
Posted By: bovine
Date Posted: 21 April 2017 at 20:03
Look closely at the break has it got tiny worm like holes.
Because of the type of bolt it would be very difficult to over tighten, did you feel them break when undoing them?
David
Date Posted: 22 April 2017 at 23:59
I bought recently the  boat and just started to sail. The screws were all broken except one, just realized that as one screw was out, then I checked the others but all were broken, so no tightning from my side. I wonder if former owner might have hit something with the rudder and that broke the screws?
Posted By: marcopone
Date Posted: 03 May 2017 at 21:38
In my case I had the same problem from first day.
My H575 is one of the first.
I continuously was finding the bolts partially unscrewed and had to screw them tight very often.
No one had ever been broke though.
What could be happened in your case is that the bolts were almost completely unscrewed and then eventually broke do to excessive load.
I am quite sure that this does not depends to having hit something with the rudder.
In my case I completely resolved this issue using longer bolts and installing self locking nuts from the other lover side you can access from the aft cabins.
I put large washers before the nuts to avoid damages to fiberglass.
As I did not had any broken bolts this solution was quite simple, to take out the broken bolts could be very difficult and help from an expert mechanic may be needed.
Posted By: Jode7
Date Posted: 13 May 2017 at 10:50
Question.
My boat did not come with an emergency tiller to couple onto the top of the rudder post as shown above. Was I supposed to have one supplied with the boat or is this an option I needed to buy? When I purchased the boat I was told that each wheel worked independently of each other and an emergency tiller was not required which seemed a little strange to me especially when there is provision for one to go down through the cockpit floor and onto the top of the rudder stock. I have never removed the cover off the top of the rudder stock to see what was in there.
Date Posted: 13 May 2017 at 14:49
Same for me, no tiller.
I think the part on top of the rudder who is creating us some problems is not for that use.
Date Posted: 13 May 2017 at 15:29
John,
I think the round bar on the top of the rudder is used for lifting the rudder up into place. We were told the same thing about the independent wheels and so no requirement for an emergency tiller. In the first few months of having our boat the drive chain came off the drive for the stbd side wheel and the port side still worked. Obviously the top of the rudder can not be accessed with a tender in the garage so an emergency tiller could not be used anyway.
Cruising, currently in the Mediterranean.
Posted By: SausalitoDave
Date Posted: 13 May 2017 at 17:01
Pretty sure the round bar is the attachment point for the emergency tiller.  At least that is the case on my 505.  I also think that an emergency tiller is shipped with all boats.  Pretty important.  Any good shop could make one out or SS round stock.  I am not at the boat, or I would send a photo.
Posted By: Wild
Date Posted: 16 May 2017 at 20:39
I agree with Dave, in BELGIUM you dont get your commercial licence for charter when there is not a good working emergency tiller on board. If a dealer tells you that you dont need this is Bulls... IMO.
Wild and Wet
Belgium
545e#268
