Anchor upgrade
Forum Name: 385/388
URL: https://www.myhanse.com/forum_posts.asp?TID=10245
Printed Date: 28 March 2024 at 11:53 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Anchor upgrade
Posted By: Mark&Catherine
Subject: Anchor upgrade
Date Posted: 05 May 2017 at 09:00
Has anyone tried a 20kg Vulcan or Rocna on a 385?
Posted By: bovine
Date Posted: 05 May 2017 at 19:06
Hi Mark / Catherine I have a 20 kg Rocna on my 430 made it myself wieghs 25 kg actually , Brillient Fantastic If you go on line you can find drawings for the full range of Rocna anchors. I'm sure there not there so we can all start making our own, but I could never bring myself to pay there £600 plus David
Posted By: MikeB
Date Posted: 13 January 2018 at 06:41
Hi Mark & Catherine, After 5 years I lost faith in my 16kg Delta. In the week before Christmas I installed a Sarca Excel 22kg (an Australian brand in the league of Rocna & Manson). The 22kg model was the recommended model for the size & weight of the 385. I took my yacht to Sydney for the New Year period. The Sarca set first time each time even in 15m of water & a mud bottom in Athol Bay, Sydney Harbour on New Year's Eve. Naturally I had to extend the bow roller fitting. I extended it 200mm and, for the first time, my anchor is clear of the bow at all times. Mike
------------- Mike
Posted By: charentebob
Date Posted: 13 January 2018 at 09:18
Mike Have you tried your Sarca Excel in weed yet? I usually find that’s the toughest test. Our Delta is perfect in sand & mud. Nigel
Posted By: MikeB
Date Posted: 13 January 2018 at 11:57
Hi Nigel,
Understand that weed is always a challenge with any anchor, but where we operate weed is not normally a major problem but remember I only fitted this anchor a few weeks ago so it is early days yet. And we had a southerly change on New Year's Day in Sydney Harbour and, again, this anchor held fast where the Delta had failed me dramatically in the past. I have a copy of independent testing of a range of anchors in various conditions. Happy to share it if you would like to send me your email address. Regards, Mike
------------- Mike
Posted By: Persse
Date Posted: 14 January 2018 at 03:25
I carry one of these for high weed areas. A Marsh Stockless. Namely Tasmania and South Australia. The Sarca is a good anchor. I would love to know how you extended the bow MikeB.
Posted By: MikeB
Date Posted: 14 January 2018 at 05:17
Templates were made for the side-plates & the chain slide plate extension & these were used by the laser cutter to cut the plates. The 2 side-plates & chain slide plate extension were fully tig welded. I inserted a bolt with back nuts at each side plate at the original location of the roller for extra stiffness but that was not really necessary. Regards, Mike
------------- Mike
Posted By: Persse
Date Posted: 14 January 2018 at 06:20
Got it. That is very interesting and great work! Is the extra weight noticeable at all, and is it harder to reach the pin? Phil O.
Posted By: MikeB
Date Posted: 14 January 2018 at 10:21
Yes. The extra weight is noticeable. It is a significant weight increase & you are lifting it a further 200mm out. But the most significant thing is that you are releasing an anchor that has actually dug in & doing its' job like you haven't experienced before. Re reaching the pin, the pin never worked from day one when the yacht was new because the hole in the Delta anchor did not align. For the first time I now have a pin that actually secures the anchor. Sure, it is a reach but it is worth the reach. Best Regards, Mike
------------- Mike
Date Posted: 15 January 2018 at 09:46
Hi Mike
Thanks. I’d be interested in receiving the anchor test results. Nice work on your anchor changes.
Nigel
Posted By: MikeB
Date Posted: 15 January 2018 at 10:38
Hi Nigel, Below is some independent test results on anchors. I have been reading everything I could find on anchors for the past 2 years & Cruising Helmsman has also published many good articles on the subject. The one rider is that there is no perfect anchor for every situation one might encounter. I also had a number of conversations with Rex Francis of Anchor Right who design & manufacture the Sarca anchors. I already have the thumbs up from the Admiral after this short time. Regular multiple anchoring attempts does not do anything for good relations with the Admiral on the yacht. Best Regards, Mike
------------- Mike
Posted By: alidal
Date Posted: 15 January 2018 at 20:50
http://www.chainsropesandanchors.co.nz/catalog/view/theme/newa/images/PDF/Robertsons-TATS-AnchorTestChart.pdf" rel="nofollow - http://www.chainsropesandanchors.co.nz/catalog/view/theme/newa/images/PDF/Robertsons-TATS-AnchorTestChart.pdf
------------- Hanse 400#655
Posted By: Captain Haddock
Date Posted: 23 January 2018 at 04:59
Hi Mike,
Can I ask how much chain you have? I am about to increase my chain from 30 to 60 metres and replace the Delta 16kg with a Rocna 20kg. This is for an east coast trip this winter. Interested in your opinion.
------------- Steve H385 Rocinante
Posted By: MikeB
Date Posted: 23 January 2018 at 11:49
Hi Steve, My yacht,
"Elara" came with 30m chain & 20m of rope. Not enough for Sydney
Harbour at New Year or some parts of the Hawkesbury River area that I frequent.
As part of my anchor upgrade I have added another 30+m of chain so now have
60+m of chain & 20m of rope. You are making the right decisions for your
trip so that you can sleep well no matter what the conditions. But you still
need to be careful once you get into the Whitsundays where you may be anchoring
in coral debris on the shores of some of the islands. Enjoy your trip.
Best Regards, Mike
------------- Mike
Date Posted: 16 September 2018 at 04:35
Hi Mark and Catherine. I know this is an old thread but I installed a 20kg Rocna on my 385 earlier in the year prior to a cruise on the Australian east coast(ongoing). I’m very impressed with the holding power of the anchor and can recommend it for the 385. It fits without modification to the bow roller fitting. A slight modification to the roller allows the pin to fit in front of the anchor to hold it securely. I also installed 60m of 8mm G4 chain and haven’t noticed any weight issue. I can provide photographs and further details if it’s of further interest.
Posted By: Breathe
Date Posted: 16 September 2018 at 11:29
Hi All,
We used the Delta on Breathe for the first time last week. The anchorage was a well known location where the CQR on our old boat set first time every time. It took three attempts for the Delta to set with the anchor dragging when applying engine reverse to dig it in.
We eventually got it to set by using a very low level of engine power, and building power slowly, but did not have a lot of confidence in the amout of grip available.
Is that a typical experience with the Delta?
Thanks Gordon
Posted By: Persse
Date Posted: 16 September 2018 at 12:54
Hi Gordon The way you describe is the way we have set the anchor from Port Phillip and around N.E.Tasmania and up to Cairns. Gently reverse and gradually increase power. We still just use the 16 kg Delta that came with the boat. It has been adequate, but that is all. They are a basic middle performing anchor that at 16 kilos is at the lower end for a boat set up with sprayhoods and other wind catching gear. I stuck with mine because of it fitting into the bowsprit. Once set I haven't had a problem except on really bad ground. My spare is a weed and rock specialist anchor, but I will definitely get something like the rocna described above when we go on our next extended cruise for a primary anchor. Phil O
Date Posted: 18 September 2018 at 12:23
my problem with the rocna is that it looks like the hoop will foul the furling drum on my furlstrom gennaker, do you use a furlstrom Steve?
Posted By: Mr Bluesky
Date Posted: 28 September 2018 at 15:05
Hi I am looking at a Rocna 20kg for my 385, as next season we’re circumnavigating British Isles. Experience over the last three years is the Delta is ok in sand or mud, but any forage present and it simply slides. If you have pics you can share that would be much appreciated, don’t really want to modify the bow too much, but small amount quite acceptable. Interested to hear from anyone regarding the Rocna hoop fowling the furling gear of a Genacker.
------------- Mr Blue Sky - 385 #359 - Sail safe sail Hanse.
Posted By: AndyS
Date Posted: 29 September 2018 at 16:39
We have had good luck over the past year with our Mantus 35 pound stainless anchor. It fits well and never has slipped on us. Their swivel is also really good and heavy duty. I think Mantus is a great company with innovative products and everything is very high quality. Where we sail the bottom is pretty soft and muddy, so I cannot say how it would do in other situations.
------------- Andy Moonraker River Dunes, NC
Date Posted: 03 October 2018 at 21:56
Is the 15kg size sufficient for the 385, as it’s at the max for the size of boat. Just wondered if you have ever wished you’d gone for a 20kg?
Posted By: AndyS
Date Posted: 04 October 2018 at 14:18
We have had no problem using the 35 pound Mantus, although I have not tried it in anything approaching storm conditions. The next size up was 45 pounds and I did not think it would fit on the bow roller without modifications. I carry an extra Fortress anchor on board, and I think if I ever needed more holding power I would deploy the second anchor also.
Date Posted: 10 October 2018 at 07:57
Hi,, would it be possible to see a picture of the anchor on the bow roller, and what small mod did you carry out to retain the anchor? I am looking at the Rocna 20Kg but don’t want to have to perform any drastic changes. Thanks.
Posted By: AndyS
Date Posted: 10 October 2018 at 21:57
Date Posted: 12 October 2018 at 17:30
Thanks for this. I have just been sold a 20kg by Jimmy Green Marine in UK, they said it was their best seller and strongly recommend. They have also said they will exchange for the Mantus if it does not fit as I wish, so I have a few months to play around until I’m likely to drop it in the water. I know it’s sales pitch, but as far as I can see the rollbar type all pretty much work the same, pay your money take your choice. I’ll post a picture once I’ve finished faffing. Thanks again. Adrian.
Posted By: AndyS
Date Posted: 12 October 2018 at 17:50
Keep us posted!
Date Posted: 09 November 2018 at 20:41
20kg Rocna now fitted with Mantus 6-8mm swivel, needed to file down a little off the retaining pin same as you. Tried the larger swivel but that won’t fit through the side profile of the bow roller, but the smaller one still looks pretty chunky and I’m confident will perform as required. Also increased chain length to 50m, anymore and it starts to pile up, and that causes the chain to catch in the Gypsy when feeding out.
Can’t wait for Spring - November sucks!
Posted By: AndyS
Date Posted: 09 November 2018 at 20:49
Glad the 20KG fits! That will be terrific, and coupled with the Mantus swivel should be awesome. Thanks for the update.
