Fridge efficiency
Forum Name: 370 / 375
URL: http://www.myhanse.com/forum_posts.asp?TID=10370
Printed Date: 21 April 2018 at 16:38
Topic: Fridge efficiency
Posted By: mike pearce
Subject: Fridge efficiency
Date Posted: 13 July 2017 at 17:14
I would be interested to hear of any tips or suggestions on improving the efficiency of the fridge on our 370.
We cruise in the Med for 3-4 months each season and keeping the wine chilled is a problem!
The ice compartment appears to work fine although it freezes up on a regular basis largely irrespective of the setting on the thermostat. This has the effect of icing the evaporator under the ice box.
In terms of the main fridge compartment we struggle to get this below 8 deg C despite it being on 24/7.
Has anybody encountered similar problems and if so found a solution?
Posted By: Peter Russell
Date Posted: 13 July 2017 at 20:20
In the UK mine works OK.
I have often thought about improving the ventilation around the compressor and possibly a 12V fan to help move the warm air away to aid the fridge cooling.
I believe some fridges dump their heat into the sea via cooling pipes through the hull, but that probably requires a specifically designed fridge.
I think there are also some posts on here about improving the insulation around the fridge - probably with major surgery to the kitchen area!
Peter Russell
Date Posted: 14 July 2017 at 07:05
Thanks for the comments Peter.
I have removed the cover plate by the compressor and try to keep the door open to aid air circulation. It may assist but it's hot out here !
In an effort to further improve matters I have cut some polystyrene sheets about 200 mm thick and placed them at the floor of the main fridge compartment. I have a similar sheet directly behind the front loading door and try not to use this to access the fridge unless necessary.
Taking advice ffrom Isotherm they reckon I need to keep the ice box / evaporator 'dry' and clear of ice to ensure it works most efficiently. Problem with that is we have yet tio find a solution without turning off the fridge to allow it to thaw and then moping out the water! Not sure this should be necessary.
Date Posted: 14 July 2017 at 20:11
Even in the UK I have to defrost every 3 days or so - that may be down to a relatively humid atmosphere here.  A messy job and of course everything gets warm before you can reuse the fridge.  I occasionally chip the ice off, but you need to be careful not to damage anything.
Peter Russell
Posted By: Pepote
Date Posted: 14 July 2017 at 20:45
The compressor is located in a small enclosed space Dead.
It is necessary to improve its ventilation with the following works:
1º.- Opening an air intake through the area of the compressor, near the kitchen, to facilitate its ventilation.
2º.- Improving ventilation around the compressor with a 12V fan to help move the hot air away and reinforce cooling of the refrigerator
3 .- Facilitate the exit of hot air from the chamber in which the compressor is located, opening some gap in the upper area.
If it is not done, it will never work well and will not break the compressor when it can not be refrigerated.
Jesús
Date Posted: 15 July 2017 at 09:45
This problem is covered in several topics, e.g. "isotherm fridge failure", where it among other issues, is explained, that it is important that there is sufficient voltage at the compressor.
In my boat there was a voltage drop of 0,9 V from battery to compressor due to the small diameter/length of the current supply cable.
Cook the Captain
Freya Hanse400#27
Date Posted: 15 July 2017 at 09:59
In my fridge I have placed a perspex acrylic sheet in the middle of the box, so the fridge is separated in two. The storage under the cooling unit is then somewhat colder than the space behind the lower door.  The temperature difference between the two compartments is regulated with the number of small holes drilled in the acrylic sheet.
In the fridge the temerature is now 6, respectively 9 degrees celsius.
Cook
Freya Hanse400#27
Posted By: Pepote
Date Posted: 16 July 2017 at 09:50
With my system, I get -20 ºC in the freezer and 4 ºC in the whole refrigerator
Jesús
Date Posted: 18 July 2017 at 15:55
Thanks for the various replies and the potential solutions. Some easier than others to try although improving the ventilation sounds good for starters & checking the voltage. The acrylic sheet to compartmentalise the fridge is an interesting idea.
Posted By: silversailor
Date Posted: 20 July 2017 at 21:36
I have added a small 12V computer fan at the base of my fridge. Also, put 2 soft sided pieces of product that can freeze and then be removed to keep a cooler cold. Pull one out and drape it over the horizontal grid that separates the two sections.  When it defrosts I switch it with the one in the freezer.  Sometimes I prop open the freezer door. The exterior top of the fridge gets very warm so I use a white neoprene pad to cover it.  Reflects the heat and provides addl insulation.
Silversailor
South Haven, MI USA
S/V Legacy
Hanse 370e, #9
Posted By: Mike2145
Date Posted: 31 July 2017 at 19:30
Although I have a 320 I found that the compressor fan and fins were partially blocked with dirt.  Replaced the fan with a better quality computer fan and added a separate fan to remove the warm air from the under sink cupboard where the compressor sits.  I have cut some additional holes in the floor (the hatch where the sea cocks are) and this, i think, helps draw in cool air from the bilge.
The fridge is now consuming a lot less electricity.  Mainly due to cleaning the compressor fins I suspect but removing the heat from the compressor can only be a good thing.
As a side effect its quieter with the new quality fans.
Posted By: Bruno
Date Posted: 08 August 2017 at 21:20
If you look fore of the fridge, you will find an air duck reaching the compressor compartment giving you more room to cool the compressor. One could possibly repositon the compressor or a fan here on the cupboard plywood extension reaching out from under the seat.
Keep your fridge as dry as possible. The humidity will condensate on the evaporator and create more problems.
You could also have humidity in your freon system too. The humidity will freeze and restrict the freon. If you call a technician, ask him to bleed the system before refilling. According to Isotherm, You should have a pressure of 6 psi when fridge is on and between 50 to 60 psi when turned off.
Bruno
Hanse 400, 2010 Hull 660
