Sprayhood/Bemini
Forum Name: 575
Forum Description: 575 Hints, Tips and News
URL: http://www.myhanse.com/forum_posts.asp?TID=10443
Printed Date: 20 June 2018 at 14:45
Topic: Sprayhood/Bemini
Posted By: Elgaard
Subject: Sprayhood/Bemini
Date Posted: 08 September 2017 at 20:56
Hey Fellas.
Im looking to replace my current sprayhood and Bemini, they just have an odd fit and do not overlap eachother.
What do you guys have? Throw up some pictures of your setup, i dont really want a full cockpit tent, i just want to stay fairly dry when it pours.
BR
Elgaard
Hanse 575 Hull 108
Cruising : Currently in the Med
Date Posted: 09 September 2017 at 02:16
Hanse 575 #161
Posted By: Elgaard
Date Posted: 11 September 2017 at 16:47
Rick.
Good looking boat, thank you for sharing pictures, how is the Bimini and sprayhood connected, overlapping or do you have a zipper solution like for a cockpit tent ?
Elgaard
Hanse 575 Hull 108
Date Posted: 11 September 2017 at 19:37
There is a zipper between the two...   The dodger and bimini are at the same height.   We really love the bimini in terms of creating both a shady space as well as protection from rain and spray.   The dodger is huge, but sized well for the boat.  It really gives you great visibility and good protection
One other consideration is that I sized the bimini to hold solar panels with good support.  I can get 4 or more solbian panels 150watt each on the bimini and use them to recharge the batteries while on extended trips.   The bimini would have pockets for the flexible panels.
* I spent a lot of time looking at pictures on the internet of other boats...   you should do the same before you decide.
Hanse 575 #161
Posted By: Elgaard
Date Posted: 11 September 2017 at 20:29
Rick, id love some closeups of the two connecting if you have any?, love the sprayhood,visibility and size, looks like it goes back almost to the winches, im 63 so need both as high as possible, as close to the boom as possible.
Havent decided on the solar panels yet, but its on the list, thought of placing them infront of the sprayhood
Researching like a madman (-:
Br
Elgaard
Hanse 575 Hull 108
Date Posted: 11 September 2017 at 21:41
The solar panels come with a decision on a proper battery and electrical system monitoring capability.  What comes with the boat is pretty basic.   I'd be interested in what others have done here.
* I'll see if I have pictures of the connection.
Hanse 575 #161
Date Posted: 11 September 2017 at 22:14
Best shot I have, sorry.    This one shows the zipper connection to the back of the dodger and to the front of the bimini.   The struts need to be adjusted in this shot, to take out the sag in the connector.  Since been done, but that's why it looks that way...
Hanse 575 #161
Posted By: Elgaard
Date Posted: 11 September 2017 at 22:59
Looks good Rick, much appreciated thank you.
Hanse 575 Hull 108
Date Posted: 13 September 2017 at 11:47
One more..   FWIW
Hanse 575 #161
Posted By: Elgaard
Date Posted: 13 September 2017 at 13:19
Is that a zipper or velcro solution for the last bit beyond (around) the backstays ?
Hanse 575 Hull 108
Date Posted: 13 September 2017 at 17:42
Its a zipper around the bar,  with gathered cloth around the backstays themselves (to avoid dripping).
The bimini is so big that my guy mounted it on tracks and cars so that the support arches could slide back when you take the canvas down and get it out of the way.   Worked out well.    I can get you a picture of that when I am down this weekend if you want.
Hanse 575 #161
Posted By: Elgaard
Date Posted: 13 September 2017 at 20:30
That would be great, its a beautiful setup.
Hanse 575 Hull 108
Date Posted: 16 September 2017 at 14:46
This is the track the bimini supports are mounted on.  The cars can move forward and aft to tighten the bimini or simply sweep the supports aft for when you take it down and we choose to cover it.
Its a nice setup.
Hanse 575 #161
Posted By: Elgaard
Date Posted: 27 September 2017 at 12:21
Rick thats a sweet setup, id love to see how it looks when its folded back / down too, its pretty spot on what im thinking of getting done my self, how much did it cost you, if you dont mind me asking.  Might be worth ordering it from your guy.
BR
Elgaard
Hanse 575 Hull 108
Date Posted: 27 September 2017 at 13:22
Send you via private msg
Hanse 575 #161
Posted By: Elgaard
Date Posted: 27 September 2017 at 14:31
That be great thank you much
Hanse 575 Hull 108
