Cabin Locker Hinges
Forum Name: 311 / 312 / 315
URL: http://www.myhanse.com/forum_posts.asp?TID=10586
Printed Date: 23 October 2018 at 22:27
Topic: Cabin Locker Hinges
Posted By: grumpydatagit
Subject: Cabin Locker Hinges
Date Posted: 11 January 2018 at 13:02
As always a little sea water make it way down into the cabin occationally which has sent the hinges on the locker door under the sink rusty on my 2007 315.
After some work and help from the guys in Hafele UK I managed to identify the replacement hinge. As Hafele are all over Europe I thought I would share this with you.
Hafele Part No 343.80.720
The cost 1.24 or about 1.50 each.
I am going to see if I can find the locker push button catches next - wish me luck!
Happy New Year to you all
Posted By: Peter-Blake
Date Posted: 11 January 2018 at 14:28
look here at boatoon
http://hanse.boatoon.com/de/ersatzteile/interieur/innenbeschlage/aufschraub-riegelschloss-push-lock.html" rel="nofollow - http://hanse.boatoon.com/de/ersatzteile/interieur/innenbeschlage/aufschraub-riegelschloss-push-lock.html
Blake 370
Date Posted: 11 January 2018 at 18:48
 Re the catch
I have found the packet with one of the ones I ordered last year & i see that I  ordered it from Locks on line & it was part No- 225.24.622 . I re used the push button so it matched the others( it just screws on & they do a variety of styles & Hanse have used several colours). The packet also has the reference 28YE02-1 on it & it is called a "push button Esp lock NI PL 25mm"
Lock online show a drawing with detailed sizes & finishes so one can check it is correct.
The "caravan store" is another source.
Date Posted: 11 January 2018 at 18:57
Incorrect post deleted
Date Posted: 11 January 2018 at 20:27
Hi Samue,l these include the slide on  backing / mounting plate which is very thin and there are no options on this set. These are also have a much reduced mounting hole  - 26mm aginst the standard 35mm
I got them from one of their dealers local to me in Southampton - The advice I got from them direct.
Posted By: StavrosNZ
Date Posted: 12 January 2018 at 02:32
These are standard Hafele Brand hinges, Hafele make a huge range kitchen hardware and is readily available is most corners of the world.
Find the Hafele agents in your country/town and they can source them for not much, otherwise many of the big box DIY stores stock Hafele hinges.
Stephen
2010 H400, Auckland, New Zealand
Date Posted: 12 January 2018 at 08:50
Apologies
Post deleted to avoid confusion
I should have known better as I used to buy 1000's of the things from Hafele but the code you quote is not listed in my catalogue
Date Posted: 12 January 2018 at 13:03
Hi Samuel,
No offence taken so no appologiies required.
It would be nice if we could start up a section that we all could  put our finds like these to help our fellow Hanse owners source parts.
