105% Genoa?
Forum Name: 415
Forum Description: 415 Hints, Tips and News
URL: http://www.myhanse.com/forum_posts.asp?TID=10694
Printed Date: 18 February 2019 at 03:08
Topic: 105% Genoa?
Posted By: Jeremy
Subject: 105% Genoa?
Date Posted: 04 April 2018 at 08:27
Hi Guys,
Just looking at increasing performance in the lighter airs but not keen on the expense of a code 0. I was thinking of getting an overlapping headsail which I would just leave furled in place of the self tacker.
I noticed that the standard 105% option is only about 5 to 6sqm larger than the self tacker. I have the tracks for this sail installed so it would be an easy fit, but is it it really worth it for only another 5-6sqm of sail? Does anyone have any experience here?
Thanks a lot!!!
Posted By: Scotchmist
Date Posted: 04 April 2018 at 14:30
Hi Jeremy
Not sure what Hanse model you have, perhaps it doesn't matter for these purposes. On my 312 we bought a 130% genoa, made of lighter weight cloth. Whilst the standard self tacker (we called it the blade) was good for anything above about 8 knots, below that we needed the bigger sail. It worked a treat.
Andrew
Posted By: Mark&Catherine
Date Posted: 04 April 2018 at 14:52
we have a 105 on our 385, but it is a better cloth than the self tacker as well as being slightly bigger.  It is a much better sail to sail with because I have fitted adjustable cars on the tracks so i can control the sail shape when cracked off the wind.  In hindsight i would have exchanged the self tacker for the 105 and not had a self tacker at all, but we had it because we thought we would use it when short handed.  in fact if im on my own i use the autopilot to tack the boat and set the 105 onto the new tack myself.  when sailing with the first mate (wife) she tacks the boat and i do the sail.  Having said all that, if you already have the self tacker i would seriously consider getting the furlstrom or an alternative furling gennaker, it makes a huge difference to beam and broad reaching, and we fly ours goose winged straight down wind in lighter airs.  I'm not sure i would go for a 'proper' stiff code 0 made of very fancy material unless you race, or have lots of money, or both.  We are very happy with our wardrobe of 105, furlstrom for cruising and a full A2 asymmetric spinnaker (which we use when racing or when we have more than 2 people on board who know what they are doing, as we drop it through the forward hatch without snuffing of any kind).  For completeness i would say that a furling gennaker with the torsion line sewn into the luff is way better than a top down furler on a free flying sail, we have tried both and the former has never failed to furl, whereas the latter does require more careful furling and we have had it stuck.  Hope this helps.
Posted By: Rubato
Date Posted: 04 April 2018 at 17:39
For what it is worth, here are my subjective bits on the 400
- I only use the original self tacker for cruising. It's still in good shape so I haven't moved to replace it. When I do it will be with another self tacker, as large as possible (vertical battens?) in a much better cloth/design. It still keeps the boat moving in less than 10 knots but I'm usually motoring or motor/sailing main only in less than 7-8  knots.
- For racing we have a 108% on cabin top tracks. Sheeting angle would be far too wide to anything on the side deck. This sail is competitive above 14 knots true.
- Also for racing, and below 14 knots, we have a ~129% overlapping sail. Even that sail is not competitive in less than 8 knots of breeze
So if all you're doing is cruising and your self tack is in good shape for now, I personally wouldn't spend $5K for a few extra sq meters of sail area. You really won't notice it much at all.
Hanse 400e, #168
Posted By: plattgatt
Date Posted: 05 April 2018 at 16:41
KlatschenKlatschen
370#641 "aqua d`or"
Posted By: Jeremy
Date Posted: 13 April 2018 at 01:59
Thanks for all your help. This all makes sense. I may just keep an eye out for something used.
Jeremy
Posted By: StavrosNZ
Date Posted: 26 April 2018 at 00:19
Hi Jeremy congratulations on your 415 and moving up from your 350.
I think we were sailing back across to Gulf Harbour from Rakino a couple of weekends back side by side (I have a 400 down in the canal).
Talk to Doyles, their new code 0 technology means no luff rope reducing cost to build, reducing weight and ultimately you will get a sail that you can hoist and leave furled if cruising and get benefit of in light airs. Whilst not ideally a downwind sail its significantly more effective than Self tacker and much easier to handle than gennaker.
Stephen
2010 H400, Auckland, New Zealand
Posted By: Jeremy
Date Posted: 27 April 2018 at 21:46
Hi Stephen.
Thanks for that, really enjoying the 415, a nice upgrade from the 350. We took it down to the south island over summer, down there the extra hull length made a big difference.
You must own Vilanelle then?
Ill talk to Doyles about that code zero, Id assume Id have to install a masthead forward halyard.
Jeremy
Date Posted: 01 May 2018 at 05:09
Yes Villanelle correct, depends on how close your spinnaker halyard is to top of the forestay, if you have clearance you may be able to get a swivel in spinnaker halyard and use that otherwise it may be  a new halyard box and halyard but these can be fitted with the mast in.
Doyles are pricing one for em as well and i will likely fit removable Selden gennaker prod to get both gennaker and Code 0 forward of the forestay and open up the gap between the main.
Stephen
Posted By: J&J
Date Posted: 11 May 2018 at 08:07
Hi haven't logged on for a while we have a 105 on Good Chanse and it definitely makes a difference the extra 5 or so square meters means we can keep up with a 400 down to around 10 knots of wind we brought ours from Doyle's and very happy with it
Posted By: Joey D
Date Posted: 05 August 2018 at 14:53
I'm new to sailing and still working to figure it all out.  Is there a optimal heeling angle of the 415 or is it as much as you can take?  I have a 2014 Hanse 415. thanks
Posted By: Jeremy
Date Posted: 05 August 2018 at 22:24
Hi Joey,
Yes there is an optimal heel angle. Basically, the more you heel, the less efficient the hull becomes and the more sideways slip you get in the water. Not to mention the decreased comfort factor.
I found that it was all a matter of feel in the helm etc that came with getting used to the boat. If water is reaching the toe rail a reef is overdue. You'll generally find that the boat doesn't need to sail in its ear to get the best performance.
Jeremy
Posted By: Rubato
Date Posted: 08 August 2018 at 17:35
Yes, there is an optimum amount and then it becomes too much. I'm guessing but I would say it would be similar to the 400 which I've found to be around 15-20 degrees. This would be why in light wind you put crew on the leeward side to create some heel.
Hanse 400e, #168
Posted By: Joey D
Date Posted: 08 August 2018 at 21:43
Hey Steve,
Sounds like I have to get used to getting the sides of my boat wet!  Smile
Looking forward to getting out this weekend and give it a go!!
Joe
