Gas Regulator and Hoses
Forum Name: 320
URL: http://www.myhanse.com/forum_posts.asp?TID=11066
Printed Date: 18 February 2019 at 23:26
Topic: Gas Regulator and Hoses
Posted By: Old Racer
Subject: Gas Regulator and Hoses
Date Posted: 10 October 2018 at 14:48
Looking at a site it recommends changing the Regulator every 10 years and the hose every 5.
The hose on the 320 is not very long and there are no visible signs of wear and tear.
Does any one have a view as to when they should be renewed?
Many Thanks
Hanse 320 Olicana Inverkip Scotland
Posted By: cptgood
Date Posted: 10 October 2018 at 15:00
Hi, I changed mine ( both the inside and outside hoses + regulator) and they were in good condition too but..better safe than sorry. You can find all you need @ SVB (make sure you get the right type).
Bye
Hanse320 - Hull#100/08 - Wheel - ST headsail - Yanmar 3YM30 - SD20
Date Posted: 11 October 2018 at 19:13
Mine looked OK, until I removed it & started flexing it & noticed tiny hair cracks. I know that this is only the outside, but, hey!! It only cost a couple of 's to replace, so why even query it? Just do it. The same for the regulator. Why even take the risk if recommendations are that one replaces them with properly marked items at 5 & 10 year intervals. (I change my hoses at 3 years)
Date Posted: 25 October 2018 at 20:49
Some of my DIY seems to work on the principle that I get it right the second time, so I stay away from through-hulls and gas work.  I had the system checked over and items replaced by
https://www.heatwave.org.uk/
Heatwave Plumbing & Heating
25 Bankhouse Avenue
Largs
KA30 9PF
Phone: 07773 774937
He did a very thorough job, checking the system with manometers. One thing he did do was replace the rubber pipe connection to the stove with a reinforced hose, as it can be caught by the stove when the yacht is heeled.
Date Posted: 26 October 2018 at 12:57
Many thanks for the information.
Will look to getting them to check it over
John
