RMC Bow Thurtser |
Post Reply | Page 123> |
chrisn
Sub Lieutenant Joined: 24 July 2017 Location: seattle Status: Offline Points: 15 |
Posted: 04 May 2018 at 19:56 |
The RMC retractable bow thurster on my Hanse 470 stopped working. Not sure if it's the control board or the piston but RMC seems to be out of business. Does anyone have experience with this? Thanks, Chris
lucca
Lieutenant Joined: 15 May 2006 Location: Stralsund Status: Offline Points: 47 |
Lewmar bought rmc. first they sold the original rmc Truster und lewmar label.
RMC has previously bought the engine and transmission from Lewmar. Lewmar has developed new 185 series now. But they still sell old spare parts. |
Borjebus
Commander Joined: 29 January 2013 Location: Sweden W Status: Offline Points: 111 |
I guess the little fuse has blown and the thruster is "out of sync" - it is not in the position it believes it is.
The problem is that there are no limit switches that tell the control box weather it is OPEN or CLOSED. If the initial position is known and it starts moving, it will stop when the current goes over a certain limit. Then the control box knows it is in the other end. I suppose the little fuse close to the control box is blown. Shut off the power and loosen the outer end of the piston. Replace the fuse and after power on, run to known position. Shut off the power and re-connect the piston. Now the system should be in sync again. I did this two times and then Lewmar replaced the control box with a one with higher current limit. After that, no more problems.
BÄSK, Hanse 370e #82 from 2006, Yanmar 3JH4E/SD50, 3-blade Flexofold, RMC(Lewmar) 185 Bowthruster, Vulcan 9, Simrad+B&G instruments
chrisn
The part that failed is the control board and Lewmar was not able to (or didn't want to) help me. They say they are coming out with a new 185 swing thruster but won't give a timeline.
I'm researching building my own control box using a programmable logic controller. https://www.automationdirect.com/adc/Overview/Catalog/Programmable_Controllers/DirectLogic_Series_PLCs_(Micro_to_Small,_Brick_-a-_Modular)/DirectLogic_205_(Micro_Modular_PLC) |
Borjebus
Sorry to hear about Lewmar's support but it's an interesting solution you are thinking of. If you go for that solution consider to include limit switches in both ends to avoid the present "current limit switch".
Keep us posted!
chrisn
I purchased the components and I'm moving forward.
Can you elaborate on "current limit switch"? I'm sure there I'll run into some unknowns so I'll take all the help I can get. Chris
Borjebus
There are no physical limit switches on the actuator, instead the movement stops when the current goes over a certain limit. Without physical limit switches you cannot be 100% sure if the thruster is in or out. If you have a jam, or if you shut everything off in the middle of a movement, it is very easy to get out of sync - the thuster is out but you can't run it because it believes it is in.
With at least one physical limit switch it is easy to define "thruster in" as home position.
chrisn
My thruster uses an Okin OmegaDrive actuator which is designed for lift chairs and recliners and is the same unit for the Lazy Boy recliner in my living room. Similar to this:
http://medicalcentersupply.com/products/6204-omegadrive-motor/
A while back I disassembled it and discovered it does have two limit switches on either end of the screw piston that stop the arm when it's fully extended and fully retracted. Based on experimentation, I discovered you can apply power to the unit and it will extend and if you reverse polarity, it will retract. I don't believe voltage is a factor for this particular unit. The PLC should be arriving today and I'll start programming right away. I plan to post the details on the forum in case anyone else runs into the same issue. |
chrisn
Someone on the forum connected me with RMC in Sweden. Apparently, they sell only wholesale but they were nice enough to express mail me a new control box for a fee.
Wild
Vice Admiral Joined: 18 March 2010 Location: Turkey-Greece Status: Offline Points: 784 |
hello Chrisn
can you give me the info to contact the people of RMC please? in the past I have a contact with Mister Albert Ström but I lost his emailadress. I needed a controlbox too for my truster. You can send me this info by mail :deswe@telenet.be thanks Edited by Wild - 25 October 2018 at 16:24 |
Belgium 545e#268 |
