Solar panel(s)on a 455 |
Post Reply | Page 123 5> |
Richard M
Captain Joined: 06 November 2006 Location: United Kingdom Status: Offline Points: 329 |
Posted: 23 September 2018 at 20:39 |
I'm thinking of adding solar panels. I think I'd prefer to site them on the area in front of the spray hood. This area - decked out in artificial teak - is generally unused apart from being a place to stow fenders when underway.
My principal interest is the ability to top up batteries when the boat is not on shore power or motoring. I don't know whether it makes more sense to have a fixed panel - or a removable (roll up) panel which could be lashed down. I'd be very interested in any thoughts on the subject - including recommendations of suitable panels. Many thanks Richard
Richard M
(S/Y BrightStar - H 455 #90; ex S/Y Providence - H 400e #290) |
Samtutuki
Commander Joined: 12 November 2013 Location: Australia Status: Offline Points: 136 |
Flexiblible panels particularly when mounted on bimini canvas have been known to catch fire. Of course they are light weight which is often an advantage.
On my previous 445 I mounted two rigid panels above the bimini so that air could circulate underneath them to remove the considerable amount of heat generated by the panel. Equally important is to use one MPPT controller per panel to maximise energy harvesting.
Richard M
Many thanks Samtutuki. All helpful advice. Had not considered the heat generation point.
Richard
Richard M
Sea-U
Commadore Joined: 14 September 2012 Location: Norway Status: Offline Points: 459 |
I have added 3 panels with each its own cheap regulator. Now I have at least one panel giving something. |
Richard M
Thanks Sea-U. That looks to be an elegant solution. What is a "normal" PV generation on a sunny day?
Richard M
Samtutuki
Not so much room to play with on my new 315 but i managed to get 2 x 80W rigid panels over the hatch garage.
In Sydney, Australia I budget on an annual average 3.9Wh per day per watt of panel rating. |
Richard M
Thanks Samtutuki
Not sure I'll get quite that performance in the UK. I like the way you've angled the PV panels. Can you stand on them?
Richard M
Sea-U
The panel on the garage is 70 watts and expensive. The two on the "tent" is china 30 watts.
On a sunny day I get 4.5-5 Ampere. I have a battery of 350Ah. That is probably too much. I have now plenty of power.
Samtutuki
No, definitely not. But I never need to. Small boat.
Buggle
Sub Lieutenant Joined: 14 February 2015 Status: Offline Points: 4 |
I have installed two 52W Solbian SP52Q flexible panels on the dodger of my 445. Together with a Genasun MPPT charge controller and a Victron BMV-700 battery monitor installed, you can keep track of the charging behavior. This is perfect for keeping the batteries topped up.
