Jib Sheet 2:1 |
Goat
Lieutenant Joined: 26 May 2018 Location: UK Status: Offline Points: 45 |
Posted: 03 December 2018 at 20:45 |
Has anyone altered the standard jib and sheet to add a block and make a 2:1 pull? Unfurling the jib and setting it correctly close hauled is sometimes a challenge on our 385 and this would seem to be any easy adjustment. Any photos or comments not to try it from anyone who knows better would be appreciated.
S&J
I think you will find that this is a common alteration, although not everyone feels it is a good idea!
I found my jib sheet, which was originally attached as a single line to the sail, was often difficult to deploy and also to furl. I attached a block to the sail using a soft shackle but my original sheet wasn't long enough for the 2:1 return to the traveller so I bought a new 12mm braid-on-braid line. The existing line was 12mm and that's what the owner's handbook specified, however the new rope I got had quite a soft casing which quickly became "fuzzy" and added significantly to the friction. Last season I replaced this with a 10mm dynema line which has transformed things, to the extent that I'm not sure if the 2:1 purchase is actually required (although I am still using it). I'm not sure that dynema is really required, but I would definitely recommend switching to a thinner line with a smooth, hard outer casing. |
StavrosNZ
altering the jib sheet from 1:1 to 2:1 will only make the sail more difficult to furl due to increased resistance in jib sheet.
1:1 is plenty for a jib or your size, jib sheet block into the mast is rated at 2.1kn, your loads will be 20% of that so not an issue and when off the wind your sail shape will be better without the weight of a block on clew board. replace the factory jib sheet with 10mm dyneema even 8mm would be fine if your clutches can deal with it, small line will also reduce resistence. |
Stephen
Goat
Thanks both for the speedy and helpful replies. S&J - can you recall what length of dyneema sheet you required, I can't find this info in my documentation?
Brufan
Rear Admiral Joined: 16 December 2010 Location: Belgium Status: Offline Points: 629 |
I swap to a 2:1 very early in my ownership.
You need a hi-load, light and low friction block... so expensive ! Second : swap the sheet for one size smaller dyneema one (10 mm ?). Less resistance in blocks Third : there are hi loads on Jib's block attachement. Take care of this part.
Bruno
hanse 355 - 57 S/Y Spicy Ginger White hull, 2 cabins, Volvo D1-30, Selden rig, removable mainsheet track system, Simrad (now B&G)-Jefa autopilot. |
Fendant
I started with the factory supplied 12mm sheet via a block at the jib back to the rail. This made manual furling impossible, i needed a winch. Since last year I switched to a 10 mm dyneema sheet directly attached to the jib. I can now furl in my jib manually, even my wife can do it.
Captain Cook
My boat was delivered with 2:1 back in 2006
samuel
If you remove the 2:1 sheeting arrangement that many boats are fitted with when supplied you increase the load on the pulley in the mast plus the load on the turning block at the mast foot & on the clutch at the winch.. If you also reduce the diameter of the sheet then you may risk slippage at the clutch which may (note: may) mean changing the inside clutch mechanism. Conversely, if you add 2:1 you greatly reduce the loading There is a fair load on the jib. I do not know how much, but I do know that this year i had the wheel inside a new 50 dia Barton block collapse. (the one shackled to the jib) & my jib is much smaller than the OP's. I think that a 2:1 is worthwhile having. Oddly enough this year the halyard pulley in the mast head also collapsed so I have had to have the mast dropped to renew it. It has ended up an expensive repair. Edited by samuel - 04 December 2018 at 21:27 |
S&J
@samuel. The H385 is supplied without a 2:1 jibsheet (or at least my 2015 model was) and the OP is asking about installing one.
@Goat. I can see I ordered 32m of Race XP from SVB24. From memory, the owners manual specified 27m and I measured the furled clew to track as 4m and added another metre for spare. The Race XP is very stiff but has proved a good and relatively economic choice. I have changed the spinlock cams for my three dyneema halyards to larger cams (6-10mm?) but have not needed to do this for the 10mm jib sheet. Edited by S&J - 05 December 2018 at 10:52 |
Goat
Thanks again. I think that ordering 32m of dyneema, replacing the sheet but having enough for the 2:1 option will be the job to get done.
I'm really grateful of the replies, which if nothing else, reinforce my view that I have a lot to learn!
