Factory fitted Heater fix |
Sandy
Sub Lieutenant Joined: 10 September 2019 Location: Australia Status: Offline Points: 19 |
Posted: 10 September 2019 at 02:01 |
Looking where to start in solving broken(?) heating system on 470e year 2007. It isn’t operating and I have only a basic manual. Any ideas where to start tracking the heating system so I can begin the trouble shoot.
Captain Cook
Hi Sandy If you look at my profile, you will find a few informations about me and my boat - you should try to publish a few informations about yourselt too! It will be easier to respond to your questions if you tell us the name and model of your heater. I can also recommend the search function on this site: Choose Advanced search>All Forums>Any Date ,,,,,,,, and search e.g. "Webasto" The manual is available on the net, or ask me, and I'll send one. In my boat I have a Webasto 5000 and the search starts with checking the 20A fuse located near the battery. In my boat it is located in the battery compartment. It is not marked. You ought to know, the Webasto is powered directly from the battery, and it is not turned off when you cut the main curcuits. This is because the heater needs current in the cooling down period, when the blower is running. If you have power (green light) on the heater control knob, then you check the F-codes. As you see below, the fuel line needs to be free of air, so if you ran out of fuel, the heater will not start. FROM THE MANUAL: Initial Operation After the heater has been installed, the fuel supply system is to be bled thoroughly. NOTE: Owing to the low fuel consumption it is required that the heater be turned on repeatedly to fill the fuel line leading to the heater. During a test run of the heater all connections are to be checked for leakage and security. Should a malfunction of the heater occur during operation, fault isolating measures are to be performed. Shut-Down on Faults Faults related to individual heater components and malfunctions during the start-up sequence are detected in the control unit. The heater is shut down (fault lock-out) in the following cases: - no or unsuccessful start-up - temperature sensor defective - temperature limiter (interruption or short-circuit) - glow plug defective - insufficient fan speed, short circuit or interruption - fault in the metering pump circuit or overheat protection circuit (during start-up phase only) - undervoltage of less than 10 volts or overvoltage of more than 15 volts and for longer than 20 seconds (aplies to 12-volt heaters) - undervoltage of less than 20 volts or overvoltage of more than 32 volts and for longer than 20 seconds (on 24-volt heaters) - control unit defective - overheating Fuel supply will be interrupted in the event of overheating. An after-run cycle is performed as is the case when the heater is shut down manually. After the after-run cycle has been terminated, the control unit is in the fault lock-out state. An overheating condition is indicated by 10 flashing light signals of the operation indicator. Eliminate cause of malfunction. To deactivate the fault lock-out, the heater is to be briefly (min. 2 seconds) turned off and then switched back on again one time. Fault Code Display If the heater is equipped with a combination or standard digital timer, a fault code is indicated on the display of the digital timer whenever a malfunction has occurred: (The code may be shown as a blinking light, e.g 4 blinks = F04). F 00 Control unit failure / incorrect parameter set / warm start detection F 01 No start-up (after 2 start-up attempts) no formation of flames F 02 Flame extinguished (repeated >5) F 03 Undervoltage or overvoltage F 04 Premature flame detection F 06 Temperature sensor interruption or temperature sensor short-circuit F 07 Metering pump interruption or metering pump short-circuit F 08 Fan motor interruption or fan motor short-circuit or fan motor incorrect speed F 09 Pencil-type glow plug interruption or pencil-type glow plug short-circuit F 10 Overheating F 11 Temperature limiter interruption or temperature limiter short-circuit F 12 Setpoint transmitter (interruption / short-circuit) P.S. Search in 341/342 "White smoke from heater exhaust"
Edited by Captain Cook - 11 September 2019 at 10:14 |
JonB
Sandy,
Look back on my posts too, our 2007 470e was fitted with an Airtop 2500 I think, that had to be altered to pass EU requirements, it was never intended for anything other than lorry cabin use and so constantly cuts out and won't fire up. I've been in to great detail to find this out and you might have exactly the same model as we have. It won't work and needs replacing. If after reading my article you feel you have exactly the same issue contact me through the private system ad I'll discuss or happy to do so in public.
Jon B
JonB
Jon B
Sandy
Hi CC
Thank you very much for your information. I have printed it all out and will go through steps as per your instructions. Ofcourse brand name would be handy - I couldn't even find heater location, let alone the brand.. I also have a Calibra Sealine device and Googling reveals that this is a battery charger /or monitor of charging in/outputs. The device emits a buzz (from internal fan in the unit, located under chart table behind and below instrument panel). I don't know how this works either. It has a circuit breaker tripper switch on the panel and I leave this in an On position - to be sure, as I think it will activate circuit breaker switch if batteries look like they might over charge /cook. I also wrote to Hanse to ask for the oft-mentioned "Operating Instructions" quoted in the basic few photocopied pages of 470e info that came with the boat. Again, thank you for providing me with this info, I appreciate it.
Sandy
Hi Jon
I am printing out your information and thank you so much for it. I have only just located the heater so I will have to confirm brand and test it out. It's in the aft lazarette, port side. The boat came with virtually no User information so spent the past week opening and pulling cabin apart to track electrics wiring, plumbing etc. Great information, thanks again.
Sandy
Hi Jon
I have finally had success in starting and operating the Webasto heater after dismantling inlets and outlets and thoroughly cleaning. There was substantial gunk as the vessel has been idle for some years. I have learned a lot from the Captain on this forum as well his instructions were invaluable. The heater functions now and I’ve gained some knowledge. I wrote to Hanse for Operating Instructions but haven’t heard back for over a week. I only have the basic safety guide for this boat. So I’m desperate for this Operating INstructions Manual so if you’ve heard of it or anyone having it please let me know. Thank you kindly for your help
Edited by Sandy - 26 September 2019 at 06:44 |
JonB
Sandy,
I'm sure I have a Webasto manual on board and so the next time I pop down to NK I'll bring it back and pdf them over. I've change the burner element over, it looks like a small frying pan with a mesh and the mesh usually clogs. I've also tried burning paraffin as it burns at a high temperature and cleans it up. My issue is my heater will never work. I might change it but it's not high in my priorities or spoiling my sailing.
Jon B
Captain Cook
The following manuals/parts list are free to download from the internet: Edited by Captain Cook - 26 September 2019 at 22:13 |
Captain Cook
(Visit www.butlertechnik.com for more technical information & downloads.) If you cannot find the instruction manual at butlertechnik.com, You can send a PM with your email, the pdf. is 5.2 Mb, so it can not be uploaded here. Discovering the location of the heater must be fairly simple. Most Hanses have mounted the heater in aft port side. If you search for the stainless exhaust pipe (shape of a Manneken Pis penis), surely the heater is placed right inside from this. Some Hanse-owners call this place"The Bermuda Triangle" since it is a place where things have a tendency to disappear.
Edited by Captain Cook - 26 September 2019 at 22:10 |
