Generator? |
Ilkhanse
Captain Joined: 27 November 2011 Location: USA Status: Offline Points: 228 |
Posted: 27 July 2020 at 13:50 |
Hi folks. I don’t remember if a generator was an option when we bought our boat. Do any of you all have a generator on your 415/418? If so, what brand and where is it installed?
Muriel
Commander Joined: 19 February 2019 Status: Offline Points: 90 |
We have a Honda 2.2 portable which we keep in our port lazarette locker and pull out if we need extra battery charge, need to run AC power or drive our desalinator.
oheikal
Sub Lieutenant Joined: 01 August 2020 Location: Red Sea Egypt Status: Offline Points: 15 |
is this generator enough to power up your air conditioner units? If yes how many units can it power up and what BTU output?
Muriel
When I said AC, I meant Alternating Current (240v), not A/C as in Air Conditioning. Sorry if I confused you.
I don't know that it would run Air Conditioning although I know people sometimes use them for A/C in caravans. Cheers
oheikal
thanks for the clarification
Andrew6586
Sub Lieutenant Joined: 22 March 2016 Location: Uk Status: Offline Points: 14 |
I have a Fischer Panda neo in my Hanse 415. The life raft locker has been removed to fit in in the aft peak. The life raft now lives on the push pit where it is easier to access should it be needed.
Andrew
Andrew
Pete In The East
Sub Lieutenant Joined: 09 November 2020 Location: Orwell, Suffolk Status: Offline Points: 7 |
Hi, My partner and I have placed an order for a 418 (#213) and we are interested in fitting a generator. Can you tell me which model Fisher Panda is fitted and how much space it takes up in the locker please? Thanks!
Andrew6586
Fischer Panda 5000i neo- fits in the aft peak port side. Our access is via the aft cabin it may be different on the 418 as you have deck access. We did cut out the life raft locker as we felt fit ocean crossing it’s easier to have the life raft accessible on the rail at the pushpit.
Edited by Andrew6586 - 10 November 2020 at 19:01 |
Andrew
Andrew6586
Andrew
spam
Lieutenant Commander Joined: 22 February 2017 Location: Boston Status: Offline Points: 71 |
Maybe slightly off topic, but two things you mentioned caught my attention:1) you mentioned you cut out the lift raft locker. Was that to make space for the generator? What did you do, did you just glass it over or install some other access panel? I am considering making some changes to that area as it seems a very poor use of space. 2) you mentioned that you have a life raft on the rail at he pushpit, I am actually shopping for a raft right now. Can I ask what you have? How does it fit?
