Chain plates inside access |
cwetto
Commander Joined: 15 June 2009 Location: sailing Med Status: Offline Points: 127 |
Posted: 10 November 2022 at 15:36 |
Found some marks on the cabinets, which indicates that water could be dripping through the chain plates. Anybody find a way to inspect lower part of the chainplates, or cutting the wood anad installing the door is the only way?But the cabinet around chain plates could not be opened nor inspected, only throuh loadspeaker hole ;( Anybody already reseal chainplates? |
Cwetto
Hanse 540e 2007, sailing Med |
Wild
Vice Admiral Joined: 18 March 2010 Location: Turkey-Greece Status: Offline Points: 784 |
Hey Cwetto
Can you post some pictures of the cabinets? In the 545 the front panel of the cabinet under the speakers, is fixed with Keku snatch system , we can open it with the suction cups(for lifting the floorboards) from there you can inspect one side off the chainplate afterwards the bulkhead.For the other side of the bulkhead the same way , the panel of the waste tank in the front head, also with the suction cup we can remove the front panel. Till now we haven’t issue’s with leaks there. I try to find pictures I am not sure for the 540. |
Belgium 545e#268 |
cwetto
Cwetto
Wild
Can you check by the loudspeaker hole there are this kind of attachments on the big front inside the cabinet ?
if so, you have to cut the seals(ceiling, bottom and at the bulckhead) then you can take the front off by pulling hard with 2 suction cups. I hope this works for you.
Belgium 545e#268 |
cwetto
Thanks, will check before cutting the wood :)
I am starting to explore situation indside after we noticed black marks on outer side (visible on first picture below the hanging cabinet, caused by inside mold, water and dirt.
Cwetto
itamary
Lieutenant Joined: 26 August 2010 Location: Israel Status: Offline Points: 28 |
I had recently detected the chainplates were leaking both side of the living room The standing cabinets had to be taken out, the plates disconnected from the hull and all the complex taken out. Recaulcking and then all back in place. If u need pictures of what's going on I can send.
cwetto
Already done. Wood cut, chain plates removal, recaulking, Edited by cwetto - 13 March 2023 at 12:02 |
Cwetto
coastaldoctor
Sub Lieutenant Joined: 12 March 2023 Location: Washington DC Status: Offline Points: 7 |
Dear Itamary, I have a corrosion issue visible from the outside of the boat (Hanse 495). My feeling is that I need to potentially remove the chian plate to really understand if there is corrosion on the inside side iof the plate. My question for you is: approximately how much was the cost of removing the chain plate from the hull. Any information would be much appreciated.
Thanks Ariel
coastaldoctor
Dear Itamary, I have a corrosion issue visible from the outside of the boat (Hanse 495). My feeling is that I need to potentially remove the chian plate to really understand if there is corrosion on the inside side iof the plate. My question for you is: approximately how much was the cost of removing the chain plate from the hull. I know it might be different in every country, but a rough estimate could help me. Any information would be much appreciated.
Thanks Ariel
