Cockpit vhf radio extension |
Theoldcodger
Lieutenant Joined: 25 October 2021 Location: Chi Harbour Status: Offline Points: 48 |
Posted: 02 March 2023 at 18:21 |
Have any 312 or 315 owners fitted an extension VHF handset in to the cockpit area. I am in the process of deciding where the best place is to fit one. It does need room behind to accommodate the wiring end fittings. Any thoughts as to the optimum place - or where have you placed yours if you have one.
Many thanks -Julian ISOTOPE H312
grumpydatagit
Captain Joined: 22 August 2015 Location: Lymington Status: Offline Points: 225 |
I have a 2007 Hanse 315 with wheel and pedestal and a Standard Horizon remote handset socket located in the binnale that has my GPS and auto pilot controls mounted. Contact me if you need details
Kox
Captain Joined: 18 May 2020 Location: Denmark Status: Offline Points: 181 |
Julian, if I remember correctly, "Isotope" is tiller steered, right?
I don't have a stationary VHF, but I have a garmin 315i black box VHF incoming, so I face the same dilemma as you. I almost never use the chart table - it is almost a waste of space. For me it doesn't make sense, to have a VHF there. When the box arrives, I'll have to see about cable lengths and so on. But my initial favourite is to place the cable exit above the companionway with the rest of the instruments, marked "1". The handset cradle I would place the same place, and maybe have a rubber thingy to let it dangle from the sprayhood "3" when in an area where communication is used, to bring it closer to the tiller. It might interfere with the port side winch, but after the genakker is hoisted, I rarely use the winch. With "1" I have to remove the handset when leaving the boat, which is doable but somewhat annoying. Alternatively, I might place the handset around "2", but I fear, that someone might bump into it during sailing in animated weather. I can leave the handset in all the time. I don't fancy having instruments on the bulkheads. |
Hanse 315, Ella, Hull# 640
Theoldcodger
Thanks for your message - indeed Isotope is tiller steered. When I bought the boat she did and still does have a fixed VHF by the nav table. Most of the time I use a handheld VHF for marina entry comms etc. Sometimes it is useful to have the more powerful set when on passage.
My chart plotter screen is on the port bulkhead next to the companionway which is a good spot by the way. The back of it and its wiring is in a box attached to the opposite side of the bulkhead in the heads. That also works well. I quite like the idea of mounting my extension handset in your position 2 - but I take your point about someone catching on it as they go below. The other place I am thinking about is in the curve of the bulkhead kind of below where you have your winch. Do you keep your spray hood up at all times? I don't and thus would not want to place my screen where you have yours - hence the bulkhead positioning. You have given me another thought and that is to place the VHF extension above the companion way. A possible answer although not so easy to reach from the tiller.....Hmm lots of thinking to do. I'll share this conversation with my engineer chum who is doing the work for me - aren't I lucky! Many thanks and I am sure we'll arrive at a good solution. I'll let you know - ATB Julian
Ian Coverdale
Captain Joined: 19 June 2019 Location: Gosport Status: Offline Points: 192 |
We replaced useless SIMRAD wireless remote system supplied by Hanse with new system with wired cockpit remote.
Routing cable to cockpit (h445) was a challenge made slightly difficult by interconnecting cable connectors and cable being ~1m too short! To aid installation, we cut cable roughly in the middle so any joint would fall in the aft cabin. This allowed cable to be routed from each end without hinderance of the connectors. We then jointed the cable which consisted ~6-8 small wires plus a small screened audio cable so we used a length of 8-core screen signal cable plus a single screened audio cable, all soldered and neatly heatshrinked. If you are reasonably confident with a soldering iron, don't to shy of cutting the cable. Cheers.
Ian & Andrea
SV Gabrielle (H445) Liveaboards - currently Gosport UK for winter 2023/24. www.facebook.com/sailinggabrielle |
Derek Mayhew
Sub Lieutenant Joined: 23 February 2015 Location: Suffolk UK Status: Offline Points: 5 |
We have a Garmin wireless remote in a cradle on the port side just outboard of the curve. This seems fine with the added advantage of having no wiring or trailing cable when in use.
Ian Coverdale
Suggest usefulness of wireless system depends on your cruising.
We regularly do passages of two nights plus, sometimes with family/friend aboard and ditched the wireless for wired. Three reasons:- (1) The battery lasts 24-hours at best ... frequently found it dead battery. There is no shelter at our helm positions for charging cradle. (2) The thing kept going missing. Often in the off-duty crew's jacket, maybe in galley next to kettle or even in the head. (3) They are vulnerable ... and very expensive to repair or replace. Ours was damaged by lazorette lid. It's a nice idea and very sexy in our wireless world ... but it's a valuable piece of safety kit and we couldn't rely on it. For other scenarios like day-sailing or with more disciplined crew, it probably works very well. |
Ian & Andrea
Theoldcodger
Ian, Just seen your useful contribution to the vhf in the cockpit discussion. Where in the cockpit did you end up fixing your wired hand set. FYI I keep a portable handheld VHF with velcro attached and fix it to another velcro strip on the side of the bulkhead adjacent to the companion way - or it is in my pocket! both positions work well. All the best and thanks for the contribution. Julian Isotope H312
Ian Coverdale
Hi Julian,
I'm a believer that VHF should ideally be accessible by helmsman/helmswoman. Some watches, he/she may be only person awake and the boat is managed from helm. Our boat is not a 312 so wheel/binnacle/instruments may be different. The wired handset plug/socket is mounted below chartplotter in central binnacle where cable is long enough to reach either helm position. Routing cable did take a couple of hours. Cheers.
Ian & Andrea
rehfett
Sub Lieutenant Joined: 06 January 2020 Location: Germany Status: Offline Points: 11 |
Having a Hanse 315/2006 I have an additional handset located just below the Motor Panel near steering wheel.Working well for me since years now.
http://la-guapa-sy.de/
