Engine parts |
Post Reply | Page 123> |
bigcat
Lieutenant Commander Joined: 06 February 2014 Status: Offline Points: 58 |
Posted: 01 March 2016 at 20:01 |
Does anyone have part numbers for the Volvo Penta filters on the H345 handy?
I need part numbers for the oil and fuel filter and impeller for annual engine service. Also, where is the primary fuel filter located? I know the fuel tanks are under the starboard rear berth. Is the primary filter under a floor board in that berth? What's the primary fuel filter part number? Thanks much!
Brufan
Rear Admiral Joined: 16 December 2010 Location: Belgium Status: Offline Points: 629 |
for a Volvo D1-30 (may be D1-20 uses the same parts but not sure) :
oil filter 3840525 (or equivalent FRAM PH4990B) fuel filter 861477-8 (or equivalent MANN WK811-86) primary fuel filter (Delphi - Volvo but can vary) 3581078 (on my H355 it is located next to fuel tank under aft bed. Very tight fit & access) impeller 22222936 hope this helps
Bruno
hanse 355 - 57 S/Y Spicy Ginger White hull, 2 cabins, Volvo D1-30, Selden rig, removable mainsheet track system, Simrad (now B&G)-Jefa autopilot. |
GrainDeSel
Commander Joined: 04 August 2013 Location: France Perros-g Status: Offline Points: 86 |
Look at www.dbmoteur.fr. It is very helpfull Regards Jean marie |
Best regards
Jean-Marie H385#139 june 2012 |
bigcat
Thanks all for the replies. I also found this:
Impeller kit: 22222936 Fuel filter (primary): 861014 Fuel filter (secondary): 861477 Oil filter: 3840525 The primary fuel filter is hard to find. Only place I could find it is on ebay. There must be replacement filters, like Sierra (sold at west marine), but it wasn't clear to me which model. So for now I'll go with the one on ebay. If someone has a part number that is readily available in the US, please let me know. Thanks! |
Navegador
Lieutenant Joined: 18 March 2012 Location: The Netherlands Status: Offline Points: 45 |
to find correct volvo penta parts numbers, see;www.marinepartseurope.com
Navegador H355 D1-30
Navegador
improved primary fuel filter, changed standard Hanse (Delphi) in to Separ SWK2000/5U with remote control.
SausalitoDave
Commadore Joined: 13 October 2014 Location: Sausalito Status: Offline Points: 366 |
Navegador: Nice upgrade,may consider the same. How did you configure the remote control?
echoofwight
Captain Joined: 08 August 2007 Location: Portsmouth UK Status: Offline Points: 254 |
Keypart Europe is a good supplier for all Volvo service parts. (Keypart.com) they are very helpful if you call and have a good website
Steve. Hanse 341 Echo of Wight, . Deep draft and rudder, white hull, Single aft cabin. Raymarine instruments. Raymarine radar. Garmin AIS. Wheel Steering, Portsmouth.
Navegador
due the Separ filter is located under the rear bed floor I made a mechanical remote (by a rod) control.
control rod is accesseble from Sb or PS engine hatch.
bigcat
About a year and a half ago our Volvo diesel engine was replaced because Volvo had an exhaust recall.
Now I'm trying to do my first service on the engine and I cannot locate the primary fuel filter (water separator). I traced the fuel lines from the tank under the starboard aft berth to the engine. Nothing. We had our previous engine serviced professionally and they never mentioned the lack of a primary filter. Was it never there? Is it possible it was removed during the engine replacement?
