  New Posts New Posts RSS Feed - Genoa car for 342
Genoa car for 342
Andrew McAusland View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew McAusland Quote  Post ReplyReply Direct Link To This Post Topic: Genoa car for 342
    Posted: 19 March 2016 at 12:53
Hi, Am trying to source Genoa cars for our 342 (22 or 23 mm width) but have had as yet no success.Any ideas?.
        Andrew
Andrew McAusland
kirkelund View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kirkelund Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2016 at 09:02
Hi Andrew
The standard Hanse 342 Genoa cars are from Harken, so you are probably looking for the Harken Genoa cars (Midrange). Look here (hope the link works)Smile
http://www.harken.com/content.aspx?id=3899
Maybe you can find a local dealer on the list provided under "Find a dealer" (top menu).
(BTW, the 385 owners are VERY knowledgeable, but you could try the 342 section also WinkLOL).
Ole,
Kirkelund
"Amani"
Lynetten, Copenhagen, Denmark
Hanse 342 (grey hull, wheel steering, deep draft keel, Jefa rudder - RUD34)
Graham342 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Graham342 Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2016 at 21:13
Edited by Graham342 - 08 August 2020 at 17:32
Post Options Post Options   Thanks (0) Thanks(0)   Quote kirkelund Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2016 at 08:49
My 342 is a 2006 build fitted with Harken including the main traveller (on coach roof).
Main traveller and genoa tracks are probably the same dimension. I guess you should be able to find the on Lewmars home page. I am not sure you can combine the two makes.
Ole,
Kirkelund
"Amani"
iemand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iemand Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2016 at 09:24
Are you shire about the dimension? I think you should have Harken Midrange which is 27mm wide.
By the way I have two new Harken Midrange Pinstop cars left over....
