Some small electrical issues
Forum Name: 385/388
URL: http://www.myhanse.com/forum_posts.asp?TID=11496
Printed Date: 26 November 2022 at 16:42
Topic: Some small electrical issues
Posted By: AndyS
Subject: Some small electrical issues
Date Posted: 21 July 2019 at 17:40
Well the Victron 12/350 inverter on our 2012 385 failed abruptly after 7 years, and I just finished replacing it with their new model - a 12/375 unit. Did not feel the need to up the output since it really only powers one outlet and most of what we need are lots of USB outlets. Ended up mounting it on the other side of the partition under the seats since it is bigger and just cut large holes for the wires to go through - wires were just long enough. Now for some help . . .
Our anchor light is out, and our rigger says that the sealed LED unit on the top of the mast looks fine. Obviously the LED unit could be bad, but there could also be an issue at any point from it, down the mast, and to the panel. All the other nav lights are working normally. I've taken the panel off and looked at the switches and don't see anything loose or obviously an issue. Any ideas for something simple? I know this can end up being quite a detective project.
And one other electrical issue: the 12 volt socket on the nav panel is also not working. I think this has been a longstanding issue that I have just ignored. The 12 volt sockets in the aft berth and at the chart plotter in the cockpit both work fine. I certainly don't need it to work as we have plenty of places we can get power from, but wonder - once again - if there is something easy to look for. The wires going to it all look fine and not sure if there is a hidden fuse somewhere.
Appreciate any advice!
Andy
Moonraker
River Dunes, NC
Date Posted: 22 July 2019 at 05:48
Andy,
there are connectors behind the ceiling panel. The are used when you unstep the mast. You will see two cables coming from the swan neck. One is for the anchor light, the other is for the steaming light. Connect a 12 V source and check both. If ok, look the fuses on the Würth panel. Does your red light indicator work when you switch the anchor light on?
The anchor light fuse is a 5 A fuse on the lower processor board. There is a row 0f three 5 A fuses. The one you are looking for is the second one of these three. Before you continue disconnect panel via the main switch ! Be very careful pulling the fuse, don't let it drop on or into the electronics.
The fuse for the 12 V outlet is on the back of the upper board, it is a 10 Amp fuse.
BTW I have changed all the cheapo car fuses to automatic ones. This makes trouble shooting easier and quicker. However apart from the 12 V socket fuse I have never had another blown fuse in 6 years.
Posted By: AndyS
Date Posted: 22 July 2019 at 12:18
Thanks! Will start the detective work using your good advice.
Andy
Moonraker
River Dunes, NC
Posted By: AndyS
Date Posted: 25 July 2019 at 15:02
So I took off the ceiling piece by the mast support and checked the anchor light wire. It's getting 12 volts from the panel, so I assume the LED unit on the mast is bad and needs to be replaced, although could always be a problem (though less likely) in the wire from the mast base to the unit. Will get that replaced the next time the boat is at the yard.
As far as the 12 volt socket, I have the Phillipi board (not Wurth) and can't seem to locate the 10amp fuse for the socket. I have checked every 10amp fuse I can find and all are good. Does anyone know where the 12 volt socket fuse on the Phillipi board is hiding?
Andy
Moonraker
River Dunes, NC
Posted By: Fuego
Date Posted: 12 August 2019 at 16:40
Hi!
I have the same issue with my anchor light. have also checked an have current to the connector above the ceiling. My light is the one in the picture, are they known to fail?
Posted By: AndyS
Date Posted: 12 August 2019 at 19:05
That is the same one I have - must be prone to failure. I plan to replace with another brand when I have the chance. For now just will use a battery powered light and suspend it from a halyard.
Andy
Moonraker
River Dunes, NC
Posted By: Brufan
Date Posted: 12 August 2019 at 19:35
My original anchor light failed two years ago at the age of 7...
Bruno
hanse 355 - 57
S/Y Spicy Ginger
Posted By: Fuego
Date Posted: 12 August 2019 at 20:05
The same model of anchor light?
Posted By: CrocDundee
Date Posted: 12 August 2019 at 23:31
We had one, just like the picture. Also failed at about 6 years. Now replaced with similar, but different LED light.
Hanse 345 - Tenacious. Sailing on the Solent and now to the west coast of Scotland.
Posted By: Brufan
Date Posted: 13 August 2019 at 11:42
yes.  This very same model
Bruno
hanse 355 - 57
S/Y Spicy Ginger
Date Posted: 13 August 2019 at 16:59
A multimeter is a must in the toolbox.
Test if the bulb/diode is OK by using the continuity tester (-I<-). It will show the number 1, and when the probes touch each other you will hear a signal sound and the number will change to something like 212. If you disconnect the + and - wires, and touch the probes at the wire-ends, you will get a "1" if no current is passing the bulb. If the bulb is LED, try the +/- probe on both wires.
LED stands for "Light Emitting Diode", and a diode is a gizmo, that only permits the current to travel in one direction. On some new diodes, you can connect the +/- terminals any way you like, but as a rule, the wires have to be mounted correctly.
To sum it up: If a LED shows no light, try to reverse the polarity.
A reverse of polarity can happen when the mast-light is reassembled.
Freya H400 #27 (2006), 40HP 3JH4E, 2-cabin, 3-blade Flexofold, Aries LiftUp Windvane, Exturn 300, Jefa DD1,Simrad NX40,Icom M603(VHF)+M802(SSB)
