True size of the self-steering jib
Forum Name: 370 / 375
URL: http://www.myhanse.com/forum_posts.asp?TID=11652
Printed Date: 12 July 2020 at 06:54
Topic: True size of the self-steering jib
Posted By: tango
Subject: True size of the self-steering jib
Date Posted: 08 November 2019 at 14:48
in the documentation  of the hanse 375 t,he size of the self-tacking jib is 28.60 mē.
I measured mine and I find a maximum of 25.02 mē
( lof 14,30m x Lpg 3,50m / 2)
that it is the real size of your thank you and the dimensions if possible because I would like to make a new one.
with which fabrics and which cut?
 thank you
Posted By: Brufan
Date Posted: 09 November 2019 at 13:28
Can't help for the 370 but I had the same proportionnal difference on mine between yard's docs and reality...
I swap my original self tacking jib for a Trilam Trekking one with 3 vertical battens.
I got 1 m2 more due to a more straight leech.
This was a costly but huge improvement in yacht's drive.
Bruno
hanse 355 - 57
S/Y Spicy Ginger
