Q: 370/ Add on at the bottom of the boat
Forum Name: 370 / 375
URL: http://www.myhanse.com/forum_posts.asp?TID=11758
Printed Date: 20 February 2020 at 14:06
Topic: Q: 370/ Add on at the bottom of the boat
Posted By: Sytarida
Subject: Q: 370/ Add on at the bottom of the boat
Date Posted: 14 January 2020 at 11:49
Hi all,
We bought our Hanse 370 last summer and now I'm curious to know what is this "piece of black plastic(at least it seems like plastic) what has been added at the bottom of the boat...
We haven't yet find out what the meaning of it could be...hope some could explain it to us Wink
Thanks in advance!
Br
Tarja
Date Posted: 14 January 2020 at 12:00
Looks like a grounding plate for your radio. Made of porous bronze/copper. Do not paint.
Inside your boat you will see it connected to a yellow/green wire. (Earth).
Freya Hanse400 #27 from 2006, 40HP Yanmar 3JH4E, Teak deck, 3-blade Flexofold, Aries LiftUp Windvane, Exturn 300, Jefa DD1, Icom M802(SSB), Simrad NX40
Posted By: Sytarida
Date Posted: 14 January 2020 at 13:25
Thanks for the prompt reply & the information.
-Tarja
Posted By: alettaenmarcel
Date Posted: 15 January 2020 at 18:18
I remouved it, dit not use it for anything.
My earth is the keel for many yaers now.
Everything works perfect.
Gr marcel
Date Posted: 15 January 2020 at 21:11
If you do not know why the grounding plate is mounted, I will recommend to search the internet for information about the function of the thing before just removing it.
http://www.crew4sail.com/articles/SSB_earthing/SSB_grounding.htm" rel="nofollow - http://www.crew4sail.com/articles/SSB_earthing/SSB_grounding.htm
This link is just one of many, but it will show you that a grounding plate is a must if you ever mount a SSB/HF transciever. Keels/Engines and battery ground are not usable for SSBs. A keel with 17 layers of epoxy and antifouling may have some difficulties to get in contact with the water anyway. The grounding plate is exclusively for the radio - nothing else.
The grounding plate above is made of porous metal, bronze or copper, and is always in good contact with the sea, unless an ignorant owner has covered it with antifouling.
Just like with the IKEA furniture, read the assembly instructions - or - in other words, read a little about the item before scrapping it.
Update 16/1: My operators licence (LRC) is just for marine bands and telex, but the ham frequencies are available for listening, and also for transmitting in an emergency. The ham operators normally have a lot of knowledge about radios, and I just read, that a thick layer of antifouling on the keel is pretty good for bouncing a radiowave into the air. If you choose to connect your keel bolts to the HF/SSB radio, it has to be only the SSB radio. Otherwise you will just recieve a lot of static (noise).
Hams are radio "amateurs" with a license (GRC) to transmit on special frequencies.
Posted By: plattgatt
Date Posted: 16 January 2020 at 11:54
Daumen hochDaumen hoch?
370#641 "aqua d`or"
