Cambio olio saildrive SD/50
Forum Name: myHanse Italy
Moderator: doppiag
URL: http://www.myhanse.com/forum_posts.asp?TID=11805
Printed Date: 10 April 2020 at 20:00
Topic: Cambio olio saildrive SD/50
Posted By: margot
Subject: Cambio olio saildrive SD/50
Date Posted: 13 February 2020 at 11:07
Gent.mi ,
Con barca a terra ,per sostituire l'olio in oggetto, Ŕ sufficiente scaricarlo dall'apposito foro e poi reintegrarlo tramite il bocchettone di rabbocco ?
Sul manuale di riferimento si parla di una pompa ad hoc .
Ringrazio in anticipo
Ste
Date Posted: 13 February 2020 at 12:28
Ho il pensare che andrÓ bene usare il tappo di scarico. Ricorda di usare l'olio GL4 - Ŕ vietato usare l'olio GL5  (Just using Google Translate - and I am writing understandable Italian!)
(And Margot - just use Google to translate my answer/ basta usare Google per tradurre la mia risposta).
(I think it will be okay to use the drain plug. Remember to use GL4 oil - it is strictly forbidden to use GL5 oil)
Maybe Marco can help you with a manual: http://www.wesailhanse.se/Hanse370_documents/370_documents_yanmar/Yanmar_SD50_Verkstadshandbok.pdf
The problem with using GL5 oil in the SD50 saildrive is described in detail if you use the search function. Try "SD50", "slipping cone clutch", "GL5" e.g.
NEVER use an oil with GL4/GL5 on the label! You have to use an oil which is solely marked GL4!
The clutch in the SD50 saildrive was invented when it was allowed to use lead (Pb) in oil. It is now forbidden, and instead there are added other ingredients which are harmful for the bronze/copper in the cone clutch in SD50. Yanmar is a company of greedy "kapitalists". They still recommend GL5 for the saildrives (even though they should know better), and they have raised the price for spare parts to the SD50. Surely you can pay them for a replacement SD60 saildrive, so they can earn more money.
If Yanmar had had  a little concern about their customers, they would have issued a Technical Bulletin about the problem with GL5, and they would have lowered the price of the spare parts.
This Castrol oil is marked GL4
Freya Hanse400 #27 from 2006, 40HP Yanmar 3JH4E, Teak deck, 3-blade Flexofold, Aries LiftUp Windvane, Exturn 300, Jefa DD1,Simrad NX40,Icom M802(SSB)
Posted By: margot
Date Posted: 13 February 2020 at 17:08
Thks a lot, but I m using quicksilver high performance it s from mercury factory.
Thks again
Stefano
Posted By: StavrosNZ
Date Posted: 13 February 2020 at 20:42
Mercury high performance gear lube clearly states it is GL4, it also contains emulsifier which will mix seawater should it enter the gear case, i use Mercury high performance gear lube in my SD50.
Quicksilver high performance gearlube however is a mystery, the pack does not tell you what grade it is and some online information suggests GL4/5. I would not use any GL5 or anything that states GL4/5. If you want the technical reasons why use the search function and find my earlier posts on the subject.
Stephen
Posted By: margot
Date Posted: 14 February 2020 at 11:03
Thks Stavros,
i will follow your post
all the best
Stefano IT
