Curling boom
Forum Name: 575/588
URL: http://www.myhanse.com/forum_posts.asp?TID=12218
Printed Date: 26 October 2020 at 10:40
Topic: Curling boom
Posted By: boomjack
Subject: Curling boom
Date Posted: 15 September 2020 at 21:30
Hi there!
Did anyone of you ever had an electric or  hydraulic furling boom retrofited on his boat?
If yes, which Brand?
Any major difficulties
Thanks for helping,
Date Posted: 16 September 2020 at 15:39
Mine is not hydraulic or electric,  we use the electric winches and it works fine.   I installed a Leisurefurl boom because it was half the price of the FURLBOOM option from Hanse.  I also had it for 10 years on my prior boat, and was happy with it.   In my opinion, adding independent hydraulics or electric drives is not necessary and simply adds more stuff to maintain, repair or keep clean.
I've been able to do everything quite easily (just my wife and I) with the electric winches and the lines run back.    In fact,  I still have a messenger sitting in one of the blocks as a result of moving from the original boom to the Leisurefurl.
The only difficulty with furling booms is called "Pullback".    If you do not angle the aft end of the boom upward a few degrees the sail will not wind up the way it is in the below picture.    It will "pull back" towards the aft end of the boom or press the bolt rope against the mast.   You will either chafe the bolt rope badly or pull the luff tape apart with the force of the furling (mandrel = screw = simple machine). I simply put a mark on the topping lift and make sure that I raise the boom to that mark before furling.  Whether electric, furling or winch driven,  this is a common problem.
Date Posted: 16 September 2020 at 16:45
With your set up, what do the battens push against with the absence of batten cars.
Date Posted: 16 September 2020 at 17:48
It's not been an issue.  The batten pockets are reinforced as on any full-batten sail with supports on either side.    Its different than hauling the sail up by hand where cars might really give you some advantage.    Its a bolt-rope system,  like on a headstay,  and pretty simple to deal with.
Where you will see batten issues is when the pull-back/push-forward issue is not managed properly.  Pressing the battens against the mast (even if you had cars) will stress the pockets and cause chafe you don't want.   Same with pull-back except it will pull the luff tape and pocket apart.
Neither of these are big issues.  I include them to ensure you are informed as to the cons as well as the pros.
Posted By: boomjack
Date Posted: 20 September 2020 at 14:07
Dear Rick, sorry for my late answer, many thanks for your advice.
I did contact leisurefurl in the US and they adressed me to their rep in France.
But they stated that i have to replace my main sail.... you did not replce yours and it was a normal elvstrom fullbatten, correct?
Date Posted: 20 September 2020 at 23:56
sorry.     I built my boat and had the sails made for it.    As I doubted they had 575 HPM sails sitting on the shelf,  I had LeisureFurl send the sailmakers package to Denmark and they were made that way
You can go to a local sailmaker and see what they say once you get the sailmakers package.
Posted By: boomjack
Date Posted: 21 September 2020 at 17:30
hi Rick,
thanks, I will speak with the sailmaker as well then.
Date Posted: 21 September 2020 at 18:27
If you want to see what a sailmakers package looks like,  I can send you the one from our boat.    One the length of your boom is finalized, they should be able to give you the package.
I believe that its a flatter cut, but it also needs a bolt rope for the hoist and some other changes...   I know people who have done it, but not knowing what shape your current sail is in,  I'd get quotes both ways and make the decision.
I wanted to get a credit for the FCL sails that came with the boat as I hadn't heard much about them I liked.    It took me a while, but I was able to negotiate an "up-charge" only to move to the HPM sails.   I really like them, and after 3 years they still look great and sail great.   Full battens on the main is one reason.
Posted By: boomjack
Date Posted: 24 September 2020 at 22:37
hi Rick,
I just spoke today with Leisure Furl France And they will send me a quote for boom and sail, i sait for this and we can compare thé specs ?
Best
Date Posted: 24 September 2020 at 22:44
Sure.... lets do this via private messaging.
Posted By: boomjack
Date Posted: 25 September 2020 at 09:17
OK, i already have your mail,
