How to montage new open railing
Forum Name: 350
URL: http://www.myhanse.com/forum_posts.asp?TID=12411
Printed Date: 05 March 2021 at 08:01
Topic: How to montage new open railing
Posted By: Flemming_M
Subject: How to montage new open railing
Date Posted: 16 December 2020 at 11:17
Hello. We want to open the railing with the gate that are ment for that. I have found the Pheiffer foot for scepters. But is it necessary too drill through the deck and mount a nut unter the deck?
Or - is there a aluminium rail along the boat in the deck?  If soo - can I drill and make thread in the aluminium rail and fastend the foots with a bolt?
I found it here:  https://hanse.boatoon.com/en/shop/article/25068/Railing-feet" rel="nofollow - https://hanse.boatoon.com/en/shop/article/25068/Railing-feet    but it can be the same as used on Bavaria from 2001 - 2013.
Hope for a good tips.
Flemming M
Hanse 350/DEN233
Posted By: 350Bob
Date Posted: 16 December 2020 at 15:15
Not on a 350 but may be useful information here, have a look at this post:  https://www.myhanse.com/removing-2007-era-stanchions_topic12331_page2.html" rel="nofollow - https://www.myhanse.com/removing-2007-era-stanchions_topic12331_page2.html
Bob
H350 #205
Date Posted: 16 December 2020 at 21:17
Thanks a lot. I have read the tropic 12331. It is very useful but  looks as a troblesome montage.
Flemming M
Hanse 350/DEN233
Posted By: jeb
Date Posted: 08 January 2021 at 06:23
hi, i just finished adding gates to my h400 from 2006. On this model there were no alu plates added to the areas for the stanchion base. I had to get behind the ceiling panels to be able to add nuts and washers. On newer models there are plates, not sure about h350.
Jesper
Hanse 400e
Date Posted: 08 January 2021 at 16:59
Hey. Thanks for the info. I have open the the celling panels. And I can see, there is not a aluplate. It is only possible the same way you metions here. I will therefor not make a installation yet. It is difficult over the el-panels.
Flemming M
Hanse 350/DEN233
