Yanmar LCD display replacement
Category: General
Forum Name: Chit Chat
URL: https://www.myhanse.com/forum_posts.asp?TID=12886
Topic: Yanmar LCD display replacement
Subject: Yanmar LCD display replacement
Date Posted: 18 July 2021 at 20:59
Our Yanmar Hour-meter has not worked for years.
But today I replaced the LCD and got it working again.
The display was sourced from  http://www.akspeedo.com/vdo-lcd-repair.php" rel="nofollow - http://www.akspeedo.com/vdo-lcd-repair.php
The difficult part was getting the thin black dice with the rpm loose from the case because it was glued.
/h8jer
Hanse 370#487 30HP 3-cabin
Posted By: Brownemi
Date Posted: 19 July 2021 at 07:30
nice job.
Is it possible to replace the lens of the tachometer? Was this glued on or did it just have a rubber gasket holding it on? I have the Volvo D1-30 which looks to have the same VDO 85mm tachometer but my lens is cracked, otherwise it and the screen work perfectly.
Date Posted: 19 July 2021 at 07:35
The lens comes off the VDO tachometer when disasembly.
In the last picture I have the guts of the tachometer and it is standing upside down in the lens and the loose plastic gasket.
Posted By: MikeHum
Date Posted: 26 March 2023 at 16:15
Did anyone on this thread find out where to get the perspex cover for the rev counter from? I have tried Yanmar/Barrus but they seem only to supply the whole unit 🤔🤞
