Thanks for your comments Panos.
We do not ever use the Inner forestay without using the check stays. the inner forestay and Check stays were used for the majority of the time and always in a rough sea where there was any likely hood of any mast pumping. I assume this rules out what you are suggesting Panos was the problems?
The in 2010 Moksha did 6,500nm + from Sydney via New Zealand, Vanuatu, Solomon Islands, Papua New Guinea and back down the east coast of Australia. Some rough conditions were experienced as well as quite a lot of light wind periods in Papua New Guinea. At times in rough conditions a 2nd or a 3rd reef was used and if to windward at all, always with inner forestay and check stays. Also the storm jib was used on the inner forestay in some rough conditions combined with a third reef and check stays.
In the lighter winds quite a lot of motoring occurred at times in a rough sea . Check stays and inner forestay were always used if there was any likely hood the must would pump. the rig was tuned by a experienced professional rigger before the boat left. The rig was not tuned while the boat was away.
Is it possible that the mast could have moved a enough to cause this sort of damage at the height of the lower spreaders and for the mast at the top spreaders to be held firmly in place with the inner forestay and check stays?
I have seen a number of north sails rigging guides for Hanse but the largest they have on there website is for a 400. http://www.nz.northsails.com/nz/SailProducts/ProductionBoats/TuningGuides/HanseYachts/Hanse400/tabid/8345/Default.aspx - http://www.nz.northsails.com/nz/SailProducts/ProductionBoats/TuningGuides/HanseYachts/Hanse400/tabid/8345/Default.aspx
Does anyone have rigging guide for a 540 that includes things like rake measurement in centimetres and tensions recommended for D1, D2 etc. On the North Sails site they have information for the Hanse 540 but no rigging guide.
North Sail Hanse guides are located at
http://www.nz.northsails.com/SailProducts/ProductionBoats/TuningGuides/HanseYachts/tabid/8341/language/en-US/Default.aspx - http://www.nz.northsails.com/SailProducts/ProductionBoats/TuningGuides/HanseYachts/tabid/8341/language/en-US/Default.aspx
I am also aware of the Selden tuning guide. I note the latest version has a version date of 2010-12-21 and is 88 pages. I have seen a number of earlier versions with either 43 or 84 pages. the most up to date version can be found at http://www.seldenmast.com/_download.cfm?id=5564&download=6479462&filename=595-540-E.pdf - http://www.seldenmast.com/_download.cfm?id=5564&download=6479462&filename=595-540-E.pdf
The Sparcraft guide for tuning is located at http://www.sparcraft.com/uk/technical_support/sparcraft_recommendations/masts/summary/default.asp - http://www.sparcraft.com/uk/technical_support/sparcraft_recommendations/masts/summary/default.asp
------------- Regards Richard
Pittwater, Sydney, Australia
