IS20 Wind - Setup for VMG display?
Category: General
Forum Name: Racing
URL: http://www.myhanse.com/forum_posts.asp?TID=8456
Printed Date: 27 November 2022 at 20:00
Topic: IS20 Wind - Setup for VMG display?
Posted By: Nick_R
Subject: IS20 Wind - Setup for VMG display?
Date Posted: 19 June 2014 at 06:43
After many years of sailing without a VMG display I got interested in it this year. The most suitable instrument to use for the VMG readout turned out to be the analog IS20 wind display.
However, I have found no way to save the "display VMG" setting in the instrument and make it permanent. I.e. each time I turn on the instrument it reverts to showing apparent wind speed, and I need to set it manually to display VMG again.
Have I overlooked something in the manual, or is this just the way it works? I am mystified since on e.g. the IS20 Graphic any display configuration can be saved and is restored at next power up.
IS20 user
Posted By: kweetje
Date Posted: 19 June 2014 at 07:23
You can not do this with the analogue IS20 !
First 4000 miles, no substantial problems
Posted By: High Time
Date Posted: 20 June 2014 at 15:03
When you say "set it manually" do you mean press the up (or down) arrow button a couple of times, or something more difficult?
On my IS20 Wind (with analogue direction and digital speed read-outs) it takes 2 pushes from the start-up screen to get to VMG (in the digital 'window').
Roger
High Time (415 #038)
